D16 Swap Trouble
Old Mar 25, 2008 | 07:52 PM
jdmhondamotive's Avatar
Default D16Z6 Swap Trouble
EDIT: ok, so i decided to trade the Y8 head for a Z6, so now im running a P28 w/ jumper harness, OBD-I dizzy and Z6 manifold but yet im still getting a code 8 which is the TDC sensor. how can you go about fixing that? i was reading and alot of people used the obd0 dizzy is that true?or do i have to use the OBD0 dizzy?
Modified by jdmhondamotive at 4:41 PM 4/6/2008
Old Mar 25, 2008 | 08:21 PM
89GSRHATCH's Avatar
Default Re: D16 Swap Trouble (jdmhondamotive)
so u are running dpfi injection ?? or is your car mpfi ? what is you full set up
Old Mar 25, 2008 | 08:28 PM
2slow4stock's Avatar
What model is the car? Was the car dpfi or mpfi? If the car was dpfi the tps wires would be switched on the outside wires. (Basically do not touch the one in the middle but depin and repin the outside ones. Switch spots)
What did you modify? The engine harness plug or the dizzy plug? If you were dpfi check your wiring. Should be the 2 white wires you would have the switch if i am correct. correct me if i'm wrong.
I forget where you can tap it into the dizzy side.
Hope any of this helps.
Old Mar 26, 2008 | 06:50 PM
Default Re: (2slow4stock)
thanks for the info, the car is a 91 si, it was fuel injected but the intake mani didnt come with a tps so i had a spare tps laying around that happened to be dual point. im running a z6 intake mani now on the stock si harness. so if im reading correctly you switch the 2 outside wires and leave the middle one along?
Old Mar 27, 2008 | 07:12 PM
i re-pined the tps and still the same, it feels like it made a difference but the ecu is still reading the same so i dunno
Old Mar 31, 2008 | 07:08 AM
89GSRHATCH's Avatar
Default Re: (jdmhondamotive)
that dpfi tps your running is not right for that manifold it is set for throttle position for dpfi the only other thing i would try is with a volt meter tap in to the wires going to the tps there should be 3 and i think its the one in the middle you will no if its right because with the key on you'll have voltage if its right anyway when you have the right wire and it shows voltage losen the tps sensor and move it till the voltage say 4.5 volts then the tps will be right if this doesent fix it change the tps off a mpfi tb also do this same thing with that one too so it will work right hope this helps u
Old Mar 31, 2008 | 02:11 PM
es.roadster's Avatar
Default Re: (89GSRHATCH)
sup matt
op, the dpfi tps won't work like 89gsrhatch said. if you have a b-series throttle body with a good tps, slap it on. goodluck
Old Apr 7, 2008 | 03:54 PM
Default Re: D16Z6 Swap Trouble (jdmhondamotive)
anyone?
Civstang
17
Aug 22, 2011 05:08 PM
red_ed6
11
May 17, 2010 08:21 PM
revikan
Jan 29, 2008 03:04 PM
oldskoolcivic89
Nov 23, 2005 09:38 PM
