green flashing light on shift coumn indicator on dash please help
on my shift column indicator on my dash by spedo, it goes through all gears 12 d3 d4 but after running at higher rpms for a few minutes , no matter what gear i am in the d4 lights up with a green flashing light, i can put it in park and \the "p" lights up red but the d4 turns from flashing green to a solid green can anyone help?
should be a solid green, if its flashing randomly you might have a bad ground somewhere in the dash, or a bad bulb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bhunt726 »</TD></TR><TR><TD CLASS="quote">on my shift column indicator on my dash by spedo, it goes through all gears 12 d3 d4 but after running at higher rpms for a few minutes , no matter what gear i am in the d4 lights up with a green flashing light, i can put it in park and \the "p" lights up red but the d4 turns from flashing green to a solid green can anyone help?</TD></TR></TABLE>
That indicates a fault with the transmission.
