bad vibration
so my car started vibrating out of nowhere. once i hit about 45-50mph the front end starts to vibrate, and persists until about 80mph, after that it doesnt seem too noticeable. the thing is it only vibrates under accelleration, if i let off the gas the vibrating stops. any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg Fool »</TD></TR><TR><TD CLASS="quote">how do i go about checking to see if they are bad? i'm thinking it's the rear mount..
thanks for the help
what i did was. i use my bare hand to shake on the engine and see if it moves a bit. and to check out which one is bad. i had to use my friend's hydro car lift at his work shop. we lisfted the car up and placed a 2 by 4 long wood underneath each motor mount and slow lowered the car a bit and see if there is any crack or damage on the mount
thanks for the help
</TD></TR></TABLE>what i did was. i use my bare hand to shake on the engine and see if it moves a bit. and to check out which one is bad. i had to use my friend's hydro car lift at his work shop. we lisfted the car up and placed a 2 by 4 long wood underneath each motor mount and slow lowered the car a bit and see if there is any crack or damage on the mount
i just use my shifter as a reference. When I floor it I measure how far it moves, and in what direction- in gear.
I highly suggest prothane or es motor mounts. best upgrade possible for the money.
RICE POLICE SIP
Jan 7, 2005 03:09 PM
