Wiring fog lights
Where is the best/easiest place to go through the fire wall to enter inside the car? Also, i do not have to enter into the fuse box with my power wire, i can run it right frm the battery correct?
Thanks!
96 Accord Coupe
Thanks!
96 Accord Coupe
OEM Fogs?
or DEPO?
Need more info.
OEM go through a grommet behind the ECU/radio area
DEPO have you putting it through the driver's side grommet behind the fender
Ghetto walmart fogs just give you a wire to run anywhere
or DEPO?
Need more info.
There is a plug that you pull out (driver's side) and the harness goes through that to the fuse box. Pull up your floor mat and you should be able to see it.
I ran mine to the fuse box for the engine bay (same one used for headlights) tapped the +12V there and ran a wire through the same grommet as the wireharness for the dash. installed the switch in an empty spot where the sunroof switch would have gone on my 94 accord
TooManyHobbies
Sep 22, 2014 05:12 PM
michael-crxsi
Sep 30, 2009 06:54 AM
nerdish
Aug 9, 2001 03:13 PM
