99-00 fog light help
Old Mar 25, 2008 | 09:31 AM
BLK_TEG_007's Avatar
Default 99-00 fog light help
hey people i am going to install some fog lights on my EM1 but i cant seem to find in the FAQs the how to install 99-00 fog lights for civic cause i am a little skeptical about cutting into my bumper
Old Mar 25, 2008 | 09:46 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 99-00 fog light help (BLK_TEG_007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLK_TEG_007 &raquo;</TD></TR><TR><TD CLASS="quote">hey people i am going to install some fog lights on my EM1 but i cant seem to find in the FAQs the how to install 99-00 fog lights for civic cause i am a little skeptical about cutting into my bumper </TD></TR></TABLE>
It's seems more intimidating than it really is.
You can find detailed instructions at http://www.handaaccessories.com
You should buy a 40mm (IIRC) hole saw and a hand held power drill...that makes ALL the difference. Use a sharp utility knife. I tried it once without the hole saw, and it was a lot harder. I bought mine from ace hardware for like $7.99 or something. It came with the centering drill bit.
The bumper has little dimples as to where you should drill or cut. Just go slowly if you're scared, cut more as you have to. You'd REALLY have to F it up beyond the outline for you to be able to see the hole around the the foglight trim bezel.
It's easy. Dont be scurred.
Old Mar 25, 2008 | 10:21 AM
andoxviii's Avatar
Honda wired all EKs from just behind the driver-side headlight to inside the vehicle behind the fuse box. This means you don't need to wire anything through the firewall under the hood, and the job is fairly simple once the bumper is cut.
Good luck
actek23
Sep 22, 2007 11:52 AM
SuperImport
Jun 26, 2005 12:32 PM
