GO EF YOURSELF
Old Mar 24, 2008 | 10:26 PM
manuelesr's Avatar
Default GO EF YOURSELF
I HAVE A EF WITH A 1.5 AND WAS WONDERING IF A TRANS OFF AN 1.6 CRX SI WILL FIT AND WHICH CLUTH WILL FIT THE SI OR THE 1.5
Old Mar 24, 2008 | 10:30 PM
hailchristian's Avatar
Default Re: GO EF YOURSELF (manuelesr)
the transmission will bolt up just fine. Use your existing axles and you wont have to deal with swapping hubs or anything..
Clutch wise, 89-91 civics/crx all have the same setup...the 1988 has a different spline count.
Old Mar 24, 2008 | 10:31 PM
jdmhondamotive's Avatar
yes, it will fit, you can use either the 1.5 or the 1.6 clutch and pressure plate. you may want to count the teeth on the tranny to make sure that it has either 20 or 21 splines. from 89-00 D-series has 20 and the 88 Si has 21, i found that out the hard way. if it is off of an 88 CRX Si you have to get an 88 clutch.
Old Mar 24, 2008 | 10:32 PM
manuelesr's Avatar
Default Re: GO EF YOURSELF (hailchristian)
HOW ABOUT THE CLTCH WHICH ONE WILL FIT
Old Mar 25, 2008 | 03:19 AM
rd91sib18c5r's Avatar
Go ED yourself
Old Mar 25, 2008 | 04:26 AM
Importcustomx's Avatar
Default Re: GO EF YOURSELF (rd91sib18c5r)
HOW ABOUT TYPING IN ALL CAPS
Old Mar 25, 2008 | 05:22 AM
doublethink's Avatar
Old Mar 25, 2008 | 05:58 AM
Spikey640's Avatar
Default Re: GO EF YOURSELF (doublethink)
let the flaming begin
Old Mar 25, 2008 | 06:00 AM
90efhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manuelesr &raquo;</TD></TR><TR><TD CLASS="quote">HOW ABOUT THE CLTCH WHICH ONE WILL FIT
You have to count the splines on the SI trans and see which one it is. if it has 20 or 21 then you have to use the clutch that will fit that trans. The flywheel for the 88 is diferent also its a bit smaller.
Old Mar 25, 2008 | 06:06 AM
TheSauceSpot's Avatar
i really thought this had to do with the EF in SuperStreet.
major disapointment.
Old Mar 25, 2008 | 08:19 AM
redboy183's Avatar
Default Re: (HOTSAUCE01)
^..me too...that ef was a BEAUTY
Old Mar 26, 2008 | 04:19 PM
Default Re: (redboy183)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboy183 &raquo;</TD></TR><TR><TD CLASS="quote">^..me too...that ef was a BEAUTY</TD></TR></TABLE>
that was a nice one...
so was the RHD Crx in honda tunning
burtonripply
Sep 19, 2007 12:11 AM
LankorDie
Feb 10, 2006 05:06 PM
MakoE2
Mar 10, 2004 11:12 AM
tegboi
Oct 17, 2003 08:47 AM
tegboi
Oct 13, 2003 10:12 AM
