eg radiator in an ef???
Old Mar 24, 2008 | 09:59 PM
shosek03's Avatar
Default eg radiator in an ef???
how do i fit an eg radiator into my ef? i know it is a little bit taller than the stock ef radiator but i kinda need some room if i am to turbo my ef. i picked up and innovative mount from password but i am not sure how to position the radiator. help me out if you guys can. thanks
Old Mar 25, 2008 | 06:22 AM
90efhatch's Avatar
Its best to replace the front crossmember with an aftermarket one that has the mounts for the 92-95 radiator. You can remove the mount off of the lower tie bar on the passenger side and set the radiator in there. The radiator still wont fit in there without trimming some of the hood reinforcements. Thats how I did mine till I get the new Crossmember. My hoos is all messed up so I didn,t mind modifying it.
Old Mar 25, 2008 | 11:01 AM
shosek03's Avatar
Default Re: (90efhatch)
can i still fit a turbo kit in there with the oem radiator? i would prefer to put in a koyo single sided. you have a pic of yours you can send me? maybe that would help.
Old Mar 25, 2008 | 11:33 AM
90efhatch's Avatar
Default Re: (shosek03)
I will post one in a little bit.
spens 91 Ef
Dec 18, 2012 08:56 AM
PleadThe5th
Mar 7, 2011 03:22 PM
bigcivman09
Feb 23, 2009 06:09 PM
wickedEFguy
May 5, 2004 02:40 PM
Cereal_Killer
Jan 19, 2002 01:00 PM
