Timing Balance Shaft
Old Mar 24, 2008 | 08:13 PM
jdward's Avatar
Default Timing Balance Shaft
I'm reinstalling the timing balance shaft belt on a 2000 Accord 4cyl. The 6X100mm bolt seems to engage in two different spots on the rear balance shaft. Is there any other way to make sure I have the shaft timed properly?
Thanks
2000 Accord EX, 2.3L (F23A1), auto trans.
Old Mar 25, 2008 | 03:39 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Timing Balance Shaft (jdward)
I don't recall exactly if there is another alignment mark but it should only go in one way.
If I get time, I will pull the covers off my F22B1 and take a look. But I'm busy with some other things and I may not be able to get to this until later this week.
Old Mar 25, 2008 | 05:07 AM
jdward's Avatar
Default Re: Timing Balance Shaft (TouringAccord)
I found this reply on the "timing of balance shafts 96 Accord 2.2L" post. It's the same tech photo but describes a timing mark on the pulley. There is a photo of the timing mark with the post.
on the rear pulley there is a dot stamped into it by one of the teeth; Then when it is in the correct position it lines up with a casting boss line at about the 5'O' clock position.
if you are not replacing that oil pump seal [because you like oil leaks] then there is no need to pull that bolt out on the rear of the block, and stick an alignment pin thru the countershaft.
Look at this lude pic and you will see the mark lining up with the casting line beside the bolt.
[IMG][/IMG]
Old Mar 25, 2008 | 05:40 AM
H-T Order of Merit
do you have a link to this thread?
I don't recall even looking for an alignment mark. I just used the bolt to align the shaft, though I don't recall even moving the shaft after removal of old belt. I can say I didn't have any problems and the engine ran great after was all said and done.
Old Mar 25, 2008 | 06:09 AM
jdward's Avatar
Thanks for the help. I definately appreciate it. I want to get this back together correctly. For sure I have moved the balance shaft.
I was going to attach the photo from the thread but couldn't get it included for some reason. Anyway, here is the link:
https://honda-tech.com/zero...57674
Old Mar 25, 2008 | 06:24 AM
H-T Order of Merit
yep, no problem.
I don't ever recall looking for that alignment mark but if hondadude says it's there I believe him
Old Mar 25, 2008 | 07:13 AM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
I don't ever recall looking for that alignment mark but if hondadude says it's there I believe him </TD></TR></TABLE>
Neither did I, in fact the only thing I lined up when changing the belts before dropping in the new motor was the timing belt. I just slapped the timing balance belt on and it's running like a champ
ammoishonor
Jul 30, 2017 04:04 PM
odo53
Feb 10, 2017 11:43 PM
afreeclimber
Apr 8, 2008 10:45 AM
BolisticSi
Jan 30, 2006 10:19 AM
alfred
Aug 16, 2004 09:34 AM
