Suspension & Brakes Theory, alignment, spring rates....
CAR TOO LOW+FLAT TIRE=HELP!!!
Old Mar 24, 2008 | 06:27 PM
TightEyez's Avatar
Default CAR TOO LOW+FLAT TIRE=HELP!!!
Ok sorry didn't mean to type in CAPs. I have a 2000 integra GSR with skunk2 coilovers & tokico blues, front lowered about 3 inches & rear about 2 inches. I just got a flat tire on my rear passenger tire and now the whole passenger side is about 2 inches off the ground. My problem is I used my stock scissor jack all the way up and I still can't take the wheel off because the cars not high enough (stock GSR starfish rims). What do I do?? I'm a High School student with little to no experience if that helped any
Cliff Notes:
-Got a flat tire
-Used my stock scissor jack all the way up & still can't get the wheel off, because cars too low?
Old Mar 24, 2008 | 07:55 PM
1.3Lturbo's Avatar
Default Re: CAR TOO LOW+FLAT TIRE=HELP!!! (TightEyez)
wow
lower the car down on a block of wood or a jackstand if possible, put wood under jack, jack up again, repeat till cars in air.
I thought this was common sense.
Old Mar 25, 2008 | 04:41 PM
brzrkr's Avatar
ok use your scissor jack on the side, then when its high enough, take a regular jack and jack up from the rear tow hook, then place jack stands on sides, and to take off just reverse the order, like 1.3Lturbo said, it IS common knowledge
Old Mar 25, 2008 | 11:17 PM
egb18c5's Avatar
Default Re: (brzrkr)
i guess thats the only time scissor jacks come in handy
Old Mar 27, 2008 | 04:50 AM
408wdy's Avatar
Default Re: (egb18c5)
put the scissor jack under the lca. that way when you get the car up the suspension doesn't droop and you can take the wheel off.
Old Mar 27, 2008 | 11:57 AM
gabebauman's Avatar
Default Re: (408wdy)
Jack the car up from the rear tow hook using a hydraulic jack. If you don't have one...you need one.
Old Mar 28, 2008 | 09:57 AM
IamVtec's Avatar
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">Jack the car up from the rear tow hook using a hydraulic jack. If you don't have one...you need one.</TD></TR></TABLE>
^Im with him
Old Mar 29, 2008 | 06:21 AM
AltimaXX's Avatar
Agreed. The stock scissor jack is useless.
My quarter panel agrees. (scissor jack collapsed...crunch.)
Old Mar 29, 2008 | 06:37 PM
AFAccord's Avatar
Default Re: (AltimaXX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AltimaXX &raquo;</TD></TR><TR><TD CLASS="quote">
My quarter panel agrees. (scissor jack collapsed...crunch.)</TD></TR></TABLE>
OMG! Poor teggie!
Old Mar 29, 2008 | 07:48 PM
AltimaXX's Avatar
Default Re: (AFAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord &raquo;</TD></TR><TR><TD CLASS="quote">
OMG! Poor teggie! </TD></TR></TABLE>
Yeah...it was only a few weeks after I bought it, too. I cried The car had a pristine body before that happened...
Old Mar 29, 2008 | 08:25 PM
Jamie98RS's Avatar
holy crap never thought that could happen, I feel a little bit, going out of a driveway today and crunch goes my drivers front bumper, listening to it scrape hurt.
sleekcesar
Jan 30, 2010 01:51 PM
iiPancho
Mar 30, 2009 07:59 PM
nightshift
Honda Fit
Jul 25, 2006 06:45 AM
lilman36
Nov 24, 2003 07:49 AM
tb_pimpjuice
Oct 1, 2003 12:47 PM
