Rattling heat shield
Old Jul 9, 2002 | 09:40 AM
ScalawagD's Avatar
Default Rattling heat shield
I have a 97 Accord and the heat shield on the catalytic converter has a loud rattle.
I checked it out today and found that it was rusted out around 2 of the 4 bolts that hold it on.
Has anyone else had this problem???
I was thinking about getting a metal band clamp or something to just tighten it up.
Will that work ok, or do I need a new heat shield?
Thanks,
Brian
Old Jul 9, 2002 | 09:53 AM
YeuEmMaiMai's Avatar
Default Re: Rattling heat shield (ScalawagD)
yeah i have the same trouble I lost the lower half of my heatshield
that suxors
Old Jul 9, 2002 | 10:24 AM
Spooch69's Avatar
I had the same problem, I found some pipe wraping in the plumbing alse at wal-mart and used that, works like a charm.
Old Jul 9, 2002 | 10:25 AM
zidek_accord's Avatar
Banned
Default Re: Rattling heat shield (Spooch69)
i just ripped mine out
Old Jul 9, 2002 | 10:39 AM
SOHCmycord's Avatar
New User
Just take it off!!
Old Jul 9, 2002 | 05:58 PM
briq4's Avatar
Default Re: Rattling heat shield (SOHCmycord)
If you use the clamp idea it works great until the constant rubbing and the water that can be trapped inbetween the heat shield and the pipe will cause the pipe to leak early... I had the same problem. Just my .02.
Old Jul 11, 2002 | 09:02 PM
ScalawagD's Avatar
Thanks for the input... I am trying the band clamp for a while to see if it works out.
Old Jul 11, 2002 | 10:28 PM
Banned
i found out that the top cover on the cat itself was only held down by 1 bolt, with the other 3 being rusted out. check that out as well
Old Jul 11, 2002 | 10:31 PM
Accord94DX's Avatar
Default Re: Rattling heat shield (zidek_accord)
at honda we put two large hose clamps around the entire cat and cat shield. it works well.
Old Jul 12, 2002 | 08:47 AM
Default Re: Rattling heat shield (Accord94DX)
check this out......the guy at the brookdale honda put a metal strap around it and tightened it down free of charge when they did my timing belt service
IE it was listed on the invoice with a 0.00 dollar amount but I guess they consider that part of the 30.00 Shop supply fee
total was 638.78 and that is not too bad for the twin cities burkle honda wanted 798 for the same service....
Old Jul 12, 2002 | 09:28 AM
Larry Bastanza's Avatar
I had the same problem, Went down to NAPA and he said I stock the 9" clamps just for that purpose!! Took 5 minutes, no more rattle .
HTH,
LarryB
Old Jul 12, 2002 | 06:58 PM
hey man how much do you guys sell 15" steel rims for?
Hyard24
Sep 17, 2008 12:51 PM
White cracker yeehaa
Jan 15, 2006 03:08 PM
kid clever
Jun 28, 2004 07:22 PM
ShaolinRider
Sep 8, 2003 07:16 AM
slimbo
Mar 24, 2002 11:36 AM
