Oil on spark plugs
Old Jul 9, 2002 | 09:17 AM
wales78's Avatar
Default Oil on spark plugs
I just replaced the plugs on my 1992 Accord LX 2.2L. The two outer plugs were fine, but the two center plugs were covered in oil when I took them out. Any idea where the leak is and how to fix?
thanx
Accord94DX's Avatar
Default Re: Oil on spark plugs (wales78)
could be a lil oil from the pcv valve and whatnot, do a leakdown test.
Old Jul 9, 2002 | 09:37 AM
YeuEmMaiMai's Avatar
rings on the pistons, valve seals, i dobt it is incorrect timing as not all cylanders are affected
Old Jul 9, 2002 | 11:54 AM
HONDAGIRLL23's Avatar
I had the same problem on my 94 accord so I went ahead and replaced my valve cover gasket and spark plug gaskets.
It seems to solve the problem on my car that is.
Old Jul 9, 2002 | 11:55 AM
John's Avatar
New User
Default Re: Oil on spark plugs (HONDAGIRLL23)
Yeah, it's the spark plug seal gaskets. They're only a few bucks a piece.
Old Jul 9, 2002 | 12:30 PM
Vtecboy2002's Avatar
Default Re: Oil on spark plugs (DunReit)
My 90 Accord is having the prob, I just replaced the spark plugs 2 days ago. I thought that my motor was going to **** up on me. Thanks for the info.
Old Jul 9, 2002 | 02:57 PM
CardDealer's Avatar
Banned
Default Re: Oil on spark plugs (Vtecboy2002)
Leaking spark plug grommets are very common. Unless you have blue smoke coming out of your tailpipe I wouldnt be too worried. It's an cheap easy fix it yourself if you can take off the valve cover. It fools you into thinking the oil is coming from the combustion chamber when you take the plug out and the oil runs down onto the plug gap.
Old Jul 9, 2002 | 03:51 PM
Kazmans94cord's Avatar
same with me...its all good now.
Old Jul 10, 2002 | 05:12 AM
Stew Pidasso's Avatar
Default Re: Oil on spark plugs (kazmans94cord)
Me Too
murrellington
Mar 21, 2016 05:11 PM
F22 Accord
Oct 29, 2010 03:19 PM
JDManuel
Feb 2, 2010 05:02 PM
tonyw85
May 5, 2008 02:17 PM
LAO
Dec 14, 2007 07:36 PM
