quick ek gauge cluster question
Old Mar 24, 2008 | 12:32 PM
DCSportEJ1Civic's Avatar
Default quick ek gauge cluster question
i searched and didnt find much. i want to swap my cx cluster in my 97 for one from an ex or si. is it a direct fit? do i need to rewire anything and is there a write up?
Old Mar 24, 2008 | 12:36 PM
Midori Bandit!'s Avatar
Default Re: quick ek gauge cluster question (DCSportEJ1Civic)
I asked this once...... got a few replys. i belive if you search you will find.
BUT to answer your Q. Yes it will fit its all PNP (plug and play)
I also got an SI cluster into my CX.
Old Mar 24, 2008 | 12:43 PM
BlueIntegraBoy's Avatar
There's no need to rewire. I would swap the speedo to retain your mileage.
Old Mar 24, 2008 | 12:48 PM
Default Re: quick ek gauge cluster question (BlueIntegraBoy)
ok thanks. i searched but didnt find much.
Old Mar 24, 2008 | 01:07 PM
cmiller219's Avatar
i did the same thing. the answer to ur ? is no u dont need to do anything. u have three plugs im pretty sure behind there unplug them and plug them into the new one and the rpms will work that simple. gl
Old Mar 24, 2008 | 01:14 PM
19slocivic97's Avatar
Default Re: quick ek gauge cluster question (cmiller219)
i swapped my dx cluster for an si and it plugged in, i'm sure the cx will do the same
Old Mar 24, 2008 | 02:58 PM
wonderB's Avatar
Default Re: quick ek gauge cluster question (19slocivic97)
dont change anything, tach should work fine also.. plug shapes are exactly the same.. did it on my old ek
ajason24
Feb 18, 2009 08:12 AM
Mennouth
Aug 2, 2006 01:07 PM
Mennouth
Aug 1, 2006 08:26 AM
ekdriven
Mar 11, 2005 06:06 AM
94si94cx
Nov 15, 2002 09:07 PM
