Started my Vitara build.... had a question....
Old Mar 24, 2008 | 09:46 AM
jdmturbo1127's Avatar
Default Started my Vitara build.... had a question....
SO I finally decided to start my D16 Vitara build. After dismantling my spare block I noticed a very small "nick" at the top of the deck on the outer edge of the water jacket on the cylinder closest to the dizzy. I was wondering if this is going to cause any problems for me down the road? Is it something that I shouldnt worry about or do I need to scrap the whole block and source a new one, or the machine shop can possibly fix? Thanks!
Modified by jdmturbo1127 at 11:05 AM 3/24/2008
Modified by jdmturbo1127 at 11:07 AM 3/24/2008
Old Mar 24, 2008 | 10:25 AM
yoffer's Avatar
Banned
It doesnt look that bad at all. I would just get some sandpaper and smooth it out so that it makes a good seal when you put the headgasket on.
Old Mar 26, 2008 | 05:16 PM
Default Re: (yoffer)
Ok. Also, When I took it apart, the rod bearing on that cylinder was broke clean in half I could still rotate the crank by hand with ease, so my other question is how can I tell if the crankshaft is ruined? I would like to use the same crank if possible.... The guy I bought the block from said it started to knock just before he pulled the motor, so hopefully there is minimal damge......but I don't really know.
Old Apr 13, 2008 | 09:41 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: (jdmturbo1127)
Let the machine shop look at it.
They can usually tell if its ok.
JH4DC231
12
Oct 14, 2010 08:49 AM
ekb16
Apr 13, 2009 01:39 PM
tmrtwo
Mar 25, 2007 11:53 AM
toooslow
Jan 29, 2005 02:26 AM
Apex i ITR
Aug 12, 2002 01:34 PM
