ecu fuse keeps blowing!!!
hey guys my fuse keeps blowing for my ecu is it possible that somehow when my front speakers got installed(they had to rewire the whole system in the front because the wires were garbage) that somehow the wires got cut or crossed and its shorting it out i got them put in like a week ago.
One of your power wires are probably connected to the ground some where. Do you know anything about electrical?
If so, you could get an voltage meter and just cross reference (ohm check) your pins to ground and go from there.
If not and you think it's somthing you had done with the speakers (although I don't see how your speakers would connect to the ECU) you could just disconnect them all and see if it stops blowing the fuse. If it does then take it back to them and tell them to fix it.
jmpassey
May 31, 2018 06:46 PM
qwklude82
Aug 21, 2002 11:47 PM
