still stalling
Old Mar 24, 2008 | 05:27 AM
93 accord LX's Avatar
Default still stalling - 93 accord LX 4cyl
recap:
250k - tune up- plugs, wires, cap and rotor.
260k - o/c - put fuel injector cleaner in tank that was 1/4 full meaning to fill up...forgot to fill up until it had been driven for about 40 miles
started stalling that day during the 40 miles before i filled up.
while driving. never while idling. either while cruising or just after taking off. when it happens i have to restart it a few times and it will come back on. it will drive fine for 15 minutes to a half an hour or so, then it will stall a few times for about 5 minutes, then it is ok again for another 15 minutes to a half an hour again.
when it stalls the headlights stay on, the panel lights go out momentarily, then the check engine light comes on.
i did everything you guys suggested so far and some.
-sprayed throttle body cleaner into throttle body, and wiped clean everything i could reach inside
-ignition switch had pitted contact points-replaced
-ignition coil failed 2 out of 3 tests in haynes manual-replaced
-all the valves were loose and lock nuts were seized-adjusted valves and replaced nuts
-replaced fuel filter.
what is next?
Modified by 93 accord LX at 6:34 AM 3/24/2008
bikeboy80
Acura TSX
Jun 24, 2020 05:18 PM
random2008
Honda Civic (2006 - 2015)
Jan 13, 2019 11:31 PM
fitseries3
Aug 17, 2012 04:38 AM
Rigginit
Oct 19, 2010 09:01 PM
huepowered
Feb 26, 2007 11:18 AM
