still having starting problems
Old Mar 23, 2008 | 09:12 PM
thisiskev's Avatar
Default still having starting problems
k. i thought i figured it out. i have no idea why my car doesnt like to start. its a 89 si. i replaced fuel pump, fuel filter, spark plug wires, cap n rotor, and spark plug wires. the car started right up when i replaced the spark plug wires. and now its doing like it did before. i have to crank it for like 2 minutes and wait for it to start goin. then it starts goin and i dont have a problem anymore. the car only has trouble when the engine isnt warm. i also replaced that coolent sensor right on top of the tranny. any ideas to why my car wont start normal. the distributer is dated 2004 to so its kinda new but not really.
Old Mar 23, 2008 | 09:46 PM
ktp1598's Avatar
Listen for the main relay to click. If that's not working, it'll turn over and not start. I've seen 4 other civics with this problem. It's a large black relay on the drivers side above the kick panel about midway up. If it won't start, tap it with the butt end of a screwdriver and it'll fire.
Old Mar 23, 2008 | 10:21 PM
thisiskev's Avatar
Default Re: (ktp1598)
i'll have to give that a try tomorrow. thanks for the input.
Old Mar 25, 2008 | 01:35 PM
KazzaF's Avatar
Default Re: (thisiskev)
if its the main relay i have 2 extra ones here that I will give you cheap. I'm in washington so if you want to pay for one and try it to make sure its the main relay you can. If you replace it with the relay you got from me and it still does the same thing you can return it to me and I will give back your money.
Old Mar 25, 2008 | 10:48 PM
thisiskev's Avatar
Default Re: (KazzaF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KazzaF &raquo;</TD></TR><TR><TD CLASS="quote">if its the main relay i have 2 extra ones here that I will give you cheap. I'm in washington so if you want to pay for one and try it to make sure its the main relay you can. If you replace it with the relay you got from me and it still does the same thing you can return it to me and I will give back your money. </TD></TR></TABLE>
are you going to be at the honda-tech meet in seattle on saturday. seattle is like 3 hours away from me.
Old Mar 25, 2008 | 10:49 PM
thisiskev's Avatar
oh and if the main relay was bad would my car still run once its started. what does the main relay do. i guess i could probably search that up.
Old May 2, 2008 | 12:35 PM
thisiskev's Avatar
ok its still not starting right away. im pretty sure its not the main relay. it clicks everytime i start it. once the car has been started i can keep starting it up. then if i let it sit for a few hours. it wont start again. it will just try to crank over and then it wont for like 5 minutes. then once it starts it blows out a cloud a smoke. maybe its not getting a good enough spark. i duno. anymore ideas. has anyone had this problem.
Old May 2, 2008 | 11:21 PM
thisiskev's Avatar
no ideas? maybe distributer? anyone had this problem.
gen2_4door
23
Mar 17, 2010 06:24 AM
rexracerboy
33
Dec 30, 2009 10:40 AM
julianaa
20
Jul 2, 2007 11:44 AM
Dspad_91Civic
Aug 14, 2005 04:45 PM
.ShawnD.
Aug 31, 2002 02:57 PM
