Fuel Injector flow rate question
Old Jul 9, 2002 | 07:35 AM
GReddyB18C's Avatar
Default Fuel Injector flow rate question
Hello everyone,
Here's the situation:
1. I am currently running the stock 240cc/min injectors.
2. I purchased a set of RC 310cc/min injectors for the motor I'm building.
3. The stock 240cc/min injectors are going bad due to the fact the motor has 195,750 miles on them.
4. I've done the troubleshooting with the HELMS manual to narrow my problems down to the injectors.
5. I would like to put the RC 310cc/min injectors on my current motor and reduce the flow rate so that they flow like the 240cc/min ones, just until I complete the new motor.
6. Now the question?
In order to get the 310's to flow like the 240's, can I just use simple math to calculate the percentage I would need to lean out the VAFC fuel settings?
i.e. -> 240/310 x 100 = 77.42% -> 100 - 77.42 = 22.58%
So, if I lean out my VAFC settings 22% or 23% will the 310's be flowing like the 240's?
Any insight on this matter would be greatly appreciated. Thanks.
-Shawn
Old Jul 9, 2002 | 08:32 AM
B18CXr's Avatar
Default Re: Fuel Injector flow rate question (GReddyB18C)
should work
GReddyB18C's Avatar
Default Re: Fuel Injector flow rate question (zyg)
I have an adj. FPR already. When I installed the new Walbro fuel pump I had to turn down the pressure quite a bit to get it back to the 48 psi. (line off and pinched) that it was before.
Thanks.
-Shawn
[Modified by GReddyB18C, 11:52 AM 7/9/2002]
Old Jul 9, 2002 | 08:34 AM
Austin's Avatar
Reduce your fuel via your FPR...go to RC's website http://www.rceng.com and there is a pretty good explaination.
Austin
Old Jul 9, 2002 | 09:12 AM
GReddyB18C's Avatar
Default Re: Fuel Injector flow rate question (Austin)
If I choose to use RC's method via the fuel pressure, I would need to change the fuel pressure from 48 psi to 28.8 psi. (line off and pinched) to get the 310's to flow like the 240's. That appears to be quite low, but according to the numbers it should work.
i.e. -> [square root of (new pressure / old pressure)] x old flow rate = new flow rate
------> [square root of (28.8/48)] x 310cc/min = 240cc/min
Hmmm, I may try this. Would you guys try this? Anyone else have a suggestion? Thanks.
-Shawn
Old Jul 9, 2002 | 09:16 AM
JPP's Avatar
JPP
I ran the 310cc/min injectors on the stock ECU program for a few months. I lowered the fuel pressure to around 30 PSI via a FPR and it worked find. You will probably not be at an optimal set-up but the car will run good until you get it tuned properly.
Old Jul 9, 2002 | 10:01 AM
GReddyB18C's Avatar
Default Re: Fuel Injector flow rate question (JPP)
O.K., so the adj. FPR method will work. What about the VAFC method, just out of curiosity? Yack thinks it will work, anyone else? Thanks.
-Shawn
[Modified by GReddyB18C, 1:02 PM 7/9/2002]
wesley_925
Apr 11, 2008 08:12 PM
DIRTYsouthBB6
Nov 8, 2007 08:23 PM
cutt
Apr 25, 2006 12:12 AM
Easyslider01
Mar 16, 2005 04:27 PM
slammin86
Dec 27, 2003 03:31 PM
