Was bored this Easter Sunday (Short Throw Shifter)
Old Mar 23, 2008 | 04:18 PM
BlueCrxNC's Avatar
Default Was bored this Easter Sunday (Short Throw Shifter)
Beautiful driving weather here in NC, but too bad for me the newly running Hatchback doesn't have tags yet. After a day of mowing, tree trimming, I decided to play with my MIG Welder some more.
The end result of my 35min experiment.
Original OEM shifter was 2 inches of movement up top, from neutral to any gear, while the bottom end moved 1/2 inch. After I added some solid round steel between the pivot ball and lower joint the end result was 1 inch of movement up top equals 1/2 inch below. As you know, doing what I did leaves the cabin part of the shifter unchanged in height etc. FYI, The OEM shifter is hollow not solid.
Just thought I'd share a little part of my day.
(Yes, I know there's a ball of stray metal but I had excellent penetration throughout and it sure beats the poor factory rusted weld that was holding the original one together.)
Old Mar 24, 2008 | 06:15 AM
1xfastxhatch's Avatar
Default Re: Was bored this Easter Sunday (BlueCrxNC)
was thinkin about doin the same thing
hows it feel?
comparable to an aftermarket one?
Old Mar 24, 2008 | 08:09 AM
BlueCrxNC's Avatar
Default Re: Was bored this Easter Sunday (1xfastxhatch)
Take note I already had Energy Suspensioun bushings from a few years past which took a fair amount of play out.
Considering I have only actually driven with one other 'short shifter', which could have just been an egay special, it was a lot better. Because its still at the stock height I'm not leaning over to shift and I have nearly the same leverage as stock. A little more notchy but that's because I'm able to feel the transmissions actual shifting rod pop in and out of place. New bearings for the shifter would help out a lot in my case (old ones are a little toasted from the exhaust and 200K miles)
For those who like to do things for themself, to learn and have the feeling of accomplishment, this is a cheap thing to do.
Old Mar 26, 2008 | 04:06 AM
RS2 FAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">Take note I already had Energy Suspensioun bushings from a few years past which took a fair amount of play out.
For those who like to do things for themself, to learn and have the feeling of accomplishment, this is a cheap thing to do. </TD></TR></TABLE>
that will be the death of me oneday.................... tore apart the civic and started a k24/k20 build to see if i can........................ found out financially i can't
Dkahn18
Welding / Fabrication
13
Dec 28, 2008 09:38 PM
nk2k2
28
Apr 22, 2006 05:33 PM
97spooncivic
Dec 15, 2005 09:17 AM
ScubaStevo80
23
May 11, 2004 08:20 AM
Understeer
Dec 23, 2002 03:05 PM
