Honda S2000 Honda S2000
JDM f20c ECU, speedcut! needs to go
Old Mar 23, 2008 | 02:48 PM
americ_ian's Avatar
Default JDM f20c ECU, speedcut! needs to go
hey guys, its probably been coverd before... but speedcut does not come up in search
so thought it would be easier to post here...
just finished my ae86 + f20c.. usuing stock ecu + dash
just wondering if the old methods of getting rid of speedcut still work
ie: apexi vafc, apexi rsm, even the old school field vtec controller...
now this is a racecar... and with my 4.3 final drive, and smaller 15" wheels the 180kph speedcut is actualy coming in around 160ish... and if i have any chance at being competitive... speedcut must go!
any help
cheers
Old Mar 23, 2008 | 04:23 PM
papa5murf's Avatar
Default Re: JDM f20c ECU, speedcut! needs to go (americ_ian)
You can't, you need to pick up a US spec ECU or a UK ecu which has it's speed cut at 250kph I believe which is 155.35mph.
180kph = 111.85mph
160kph = 99.42mph
So the 160kph speed cut is correct. You can also change the gauge cluster to read mph by pushing the button.
Old Mar 23, 2008 | 05:06 PM
americ_ian's Avatar
Default Re: JDM f20c ECU, speedcut! needs to go (papa5murf)
hmmm damn....
so something like the hks speedcut defender is false advertising?
http://www.piaa.com.au/prod547.htm
Old Mar 24, 2008 | 04:45 AM
papa5murf's Avatar
I don't know, never had to use them. But the stuff you mentioned in your first post, the VAFC, Vtec controler and so forth will not work.
Why not just go with a standalone engine management system for some more power and more tuneability for your racing?
Old Mar 24, 2008 | 01:03 PM
americ_ian's Avatar
on a budget
found out, HKS make one, Js racing, and amuse, all make them
will pick up a J's one this week
metalslug
May 1, 2012 09:03 PM
Dropspeed
Dec 12, 2002 07:58 PM
si foo
15
Jul 15, 2002 01:57 AM
Jason kiDD
Mar 14, 2002 05:45 PM
