Del Sol Clutch In B16a CRX
Old Mar 23, 2008 | 02:39 PM
solvent5's Avatar
Default Del Sol Clutch In B16a CRX
Hey,
I Was Just Wondering If Del Sol Or 99-00 Civic Clutch/Flywheel Combo Will Fit Into The JDM B16? I Know Mines Cable And The Del Sol Is Hydro But I Hear Some People Saying It Will Fit And Some Say Not so I Was Wondering If Someone Could Clear Up The Confusion For Me. To Me I Would Assume That All That Would Matter Is The Number Of Splines And Not How Its Actuated
Old Mar 23, 2008 | 03:10 PM
traxxasx's Avatar
Default Re: Del Sol Clutch In B16a CRX (solvent5)
Wont fit.
https://honda-tech.com/zerothread?id=2133505
https://honda-tech.com/zerothread?id=2213787
Modified by traxxasx at 4:31 PM 3/23/2008
Old Mar 23, 2008 | 03:42 PM
Folgers's Avatar
Default Re: Del Sol Clutch In B16a CRX (traxxasx)
Order a clutch for a 90-91 integra.
Old Mar 23, 2008 | 06:26 PM
Crx Jimmy's Avatar
it should all fit if you have a ys1 (not including the throw out bearing) if you have an older cable it all will work except you will need a 91 disc. pressure plate and flywheel and pilot bearing are the same
Old Mar 24, 2008 | 03:05 PM
olskoolef9's Avatar
yeah if u use 99 flywheel,press plate,clutch disc n ur cable tranny.i know it sounds iffy but the splines on the disc r slightly bigger ,but wont work the othe way around b/c da other disc is slight smllr n da spline on da tranny wont go in
ghettoSi
Dec 8, 2010 05:20 PM
Pszemmek
Jun 5, 2008 12:21 PM
civictech22
Aug 17, 2004 03:49 PM
SuperCivic
Sep 26, 2002 11:56 AM
snake01
Feb 27, 2002 03:21 PM
