Welding stainless steel w/ Solar Flux
Old Mar 23, 2008 | 02:22 PM
david@didrace.com's Avatar
Default Welding stainless steel w/ Solar Flux
I know quite a few people come on here asking about backpurging and I'll mention using Solar Flux every now and then but haven't seen any pictures of it being used so I figured I'd post some up.
Solar Flux is silica based, and when heat is applied to it it turns into glass. When you buy it, it is a powder and you mix it with acetone or brake cleaner and it'll form a paste. I typically buy the empty pint sized paint cans w/ lids at Home Depot and a bristle type brush to mix/apply it. I'd only recommend using Solar Flux on a turbo-back exhaust because there is always a chance of the glass on the backside of the weld falling off and causing damage to something spinning at 10,000 rpms + .
On with the pics - 2.5" 304 Stainless w/ a 309L filler, Lincoln Precision TIG 375 w/ max amps set to 37, 100% argon at 25 flow, gas lense w/ a #7 cup, red 3/32" tungsten -
Old Mar 23, 2008 | 03:20 PM
hybrid2007's Avatar
I've always wondered about that stuff. Is it easy to clean off?
Why not just get set up to backpurge?
Old Mar 23, 2008 | 03:40 PM
Default Re: (hybrid2007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">I've always wondered about that stuff. Is it easy to clean off?
Why not just get set up to backpurge?</TD></TR></TABLE>
Backpurging takes longer and costs more. You can't really clean it off since most of the welds would be unreachable from the backside once welded, that's why I recommend using it only on turbo-back exhausts (or n/a).
Old Mar 23, 2008 | 04:13 PM
damnraz's Avatar
Looks good, a friend told me about this particular product and what it's uses are for. Seems like it works very well since it would cost a pretty penny trying to backpurge it 100%.
Old Mar 24, 2008 | 01:12 PM
forthrills's Avatar
Default Re: (damnraz)
Back purging A bottle of gas is much cheaper than a turbo or a motor
Modified by forthrills at 1:23 PM 3/25/2008
Old Mar 24, 2008 | 03:17 PM
HiPsi's Avatar
Default Re: (forthrills)
Been reading long?
Old Mar 25, 2008 | 05:27 PM
DESTROYER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forthrills &raquo;</TD></TR><TR><TD CLASS="quote">Back purging A bottle of gas is much cheaper than a turbo or a motor
Modified by forthrills at 1:23 PM 3/25/2008</TD></TR></TABLE>
Wise words. Or your an arrogant ***.
Old Mar 26, 2008 | 06:45 AM
ROTARY's Avatar
thanks for posting pics and info , btw has anyone got their tank filled recently? the guys at my LWS told me that the price of argon and helium went up..
Old Mar 26, 2008 | 12:15 PM
forthrills's Avatar
Default Re: (ROTARY)
Quote, originally posted by forthrills »
Jimmy
TUNINGGRüPPE
I don't know you Jimmy , so being *** or arrogant would mean you know me personally ? . being wise comes from being able and willing to listen and learn .
Old Mar 26, 2008 | 01:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forthrills &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by forthrills »
Jimmy
TUNINGGRüPPE
I don't know you Jimmy , so being *** or arrogant would mean you know me personally ? . being wise comes from being able and willing to listen and learn . </TD></TR></TABLE>
Oh god here comes the knife fight.
Old Mar 26, 2008 | 06:08 PM
efeezie's Avatar
Default Re: (david@didrace.com)
I've used it a few times. It was recommended to me to try mixing it with HEET. The inside of the tubes seemed to be alot less clumpy when finished.
Old Mar 27, 2008 | 06:25 AM
B20C1T's Avatar
last time i got my tank filled with just argon it was like $60-$70
Old Mar 29, 2008 | 06:18 PM
dave@passenger's Avatar
Default Re: (B20C1T)
Any better interior closeups? Unfortunately the only times I have used solar flux it was in a long length of tube that I didn't want to wait to purge (300+ feet,takes a while to purge )
Is it possible to get it comparable weld to backpurging if you mix it with HEET?
9TechNine9
Welding / Fabrication
Apr 6, 2018 05:14 PM
urnotfast
Jun 27, 2009 08:44 AM
andyvaj
Sep 2, 2007 05:55 PM
Flashmn
Oct 31, 2005 03:44 PM
wantboost
Feb 3, 2005 07:34 AM
