ebrake dont work
Old Mar 23, 2008 | 01:30 PM
1greatEG's Avatar
Default ebrake dont work
my ebrake dont work i have a gsr rear brake conversion on my 97 hatch i know something is wrong with this pic. how do i fix it???????????
Old Mar 23, 2008 | 04:16 PM
1greatEG's Avatar
Default Re: ebrake dont work (1greatEG)
bump for help
Old Mar 23, 2008 | 05:18 PM
afstvx's Avatar
look wherer the cables go into the calipers there should be an adjustment there
Old Mar 23, 2008 | 07:06 PM
instructor74's Avatar
Default Re: (afstvx)
There is no adjustment on the rear brake calipers. You have one of 2 things going on. 1 is a seized ebrake cable. or 2 the brake caliper has a problem. 1st remove the safety clip from the ebrake cable pin on the caliper, remove the pin and unhook the ebrake cable from the caliper make sure the cable moves freely in its sleeve. If that checks okay more then likely the problem is in ebrake mech inside the caliper and it will need to be replaced.
When you installed the rear brakes did you replace the pads? If so how did you push the piston back in? Did you make sure and relube all the slide pins with a good synthetic brake lube?
Old Mar 23, 2008 | 08:37 PM
SoCal EJ1's Avatar
"dont work" lol
760PhatBoyz
Suspension & Brakes
Sep 9, 2010 02:43 AM
cinci27
Sep 9, 2007 08:41 AM
guero2craze
Aug 29, 2007 09:28 AM
Turbo Dan
Aug 8, 2006 07:05 AM
ILcrxsi1
15
Aug 4, 2006 09:00 PM
