Power Steering Line Repair
Old Mar 23, 2008 | 12:34 PM
rmiller's Avatar
Default Power Steering Line Repair
Hi, I need to either 1) repair the flexible rubber hose or 2) add a pipe peice to my modified car.
I haven't seen adds for replacement hose connectors but I figure there must be something like this on the market. This way I can cut the flexible hose original Prelude line and scab in the peice from the accord's pwr steering pump.
The other option would be to cut the metal tube, refalre and join.
Any ideas about how to handle this?
Thanks
RJ
Old Mar 23, 2008 | 12:36 PM
Hawkze_2.3's Avatar
Default Re: Power Steering Line Repair (rmiller)
Those types of high-pressure hydraulic lines have to have ends pressed onto them. I know most auto parts stores make custom hydro lines now so you might try that.
Old Apr 4, 2008 | 01:09 PM
Keeper1343's Avatar
DON'T CUT THAT LINE!!!! You don't have a clue how much PSI is in those lines. That line will blow apart as soon as you start your car. I have tried it before. if you have a 92-96 pump get a prelude or accord line for that year. If you have a 97+ pump get the line for that pump. The threads that go into the rack or the same... one is longer than the other but it doens't matter. The threads are a 14 1.50. PM me with questions
Modified by Keeper1343 at 2:28 PM 4/4/2008
ITS_Dunn
Honda CR-V & Element
Oct 29, 2015 07:54 AM
90Acura
Jul 7, 2013 07:12 PM
Sungsu
Aug 28, 2009 08:38 AM
HONDRETTI
Apr 12, 2008 09:22 AM
dubzz24
Mar 19, 2008 04:04 PM
