Mini-Me swap in my 91 Si...
Old Mar 23, 2008 | 12:32 PM
EFstyle's Avatar
Default Mini-Me swap in my 91 Si...
Alright so last year I put my D16y7 from my old EK into my SI hatch and i just recently got a y8 head for free... I kept the 0bd0 Si ECU,Harness, and intake manifold so my question is what would be the easiest way to hook up Vtec? and then my second question is... what kind of numbers are people getting with a fully ported/polished head with lets say all Skunk2 head internals/intake manifold/throttle body? thanks for any and all input!
Old Mar 23, 2008 | 01:00 PM
EFstyle's Avatar
Default Re: Mini-Me swap in my 91 Si... (EFstyle)
Oh yeah... one more question... my buddies d16y8 has an aluminum oil pan where as mine is steel... is the aluminum pan better? and are they interchangable between y7-y8? if so im gona grab that too!!
Old Mar 23, 2008 | 04:09 PM
EFstyle's Avatar
I find it hard to beleive that nobody knows the answers to any of these questions...
Old Mar 29, 2008 | 03:55 PM
EFstyle's Avatar
Old Mar 29, 2008 | 10:09 PM
Red_ED8's Avatar
Have you checked the FAQ's? or Searched? All (if not most) of this info can be found in there. But I feel nice today so I'll help you out a little.
http://crx.honda-perf.org/arti....html
That's good info on mini-me swaps, the guy that wrote did his with a D16Z6 head (stock) and made 106 hp and 101 ft/lbs so a Y8 head should make a little more power (higher compression). As far as hp #'s with polish, cams, spring, etc, I can't help you there. And I'm not sure if the Y8's came with a aluminum oil pan or not but if it didn't I would not use one for a D/D (softer then steel). Hope this help you, and remember..... The Search button is your best friend .
Old Mar 29, 2008 | 10:14 PM
Red_ED8's Avatar
Default Re: Mini-Me swap in my 91 Si... (Red_ED8)
F$#@ that, your a 05 member you should have no problem finding info on mini-me's. Been covered a 15431454212 billion times.
Old Mar 29, 2008 | 10:22 PM
89GSRHATCH's Avatar
the metal pan is beter if your car is really low because the aluminum one will crack easy if it is hit it happend to a buddy of mine sucked *** as for running vtec the best way is to do an obd1 conversion and run a p28 ecu that will cost the most the next best thing is a vtec controller next you can use a msd rpm activator and last but not least the getto was a push botton switch i have done all off these was so i know they all work but trust me obd1 is the best hope this helps
shawnperolis
13
Sep 28, 2010 08:54 AM
prelude182
Dec 6, 2009 08:28 PM
project:JDM
Jul 30, 2009 03:07 PM
East_McDuck
May 20, 2009 05:44 PM
DieMaster
Jan 16, 2005 06:10 AM
