OBD I B16a Parts for sale, Head, Block ECU, Tranny
Ok, here is the list -
Hondata Intake manifold gasket - $40 - Never used
Cometic OEM layer Head Gasket B16a - $85
B16a LSD Tranny - Going to need a new clutch, I got a new Clutch release Fork 22821-p80-010 and spring22835-p80-000, and bearing 22810-p21-003 to go with it - $700 - pending
Brand new timing belt 14400-p2t-004 - $60
JDM CTR Crank Pulley with belt (Not sure if this will be sold) - $90
Eagle Rods for B16a CRS5290H3D - $300
B16a Head with everything, plus a complete rebuild kit with all the gaskets needed - $600
ARP Head Studs for B16a - $110
B16a Water Pump 19200-p72-013 with gasket 19222pr4003 - Brand New $60
B16a Block with All internals, just needs a head gasket / Tranny / and Head and you'll be running - $350
Unorthodox Racing Cam Gears Ultra T in Blue- $300
CTR PCT Pistons with Wrist Pin - Brand New $200
OBD I Dizzy off B16a - $150
P28 Chipped - $150
This is all just off the top of my head. . . I got a few more items, but don't remember what they were. . . Big items will be Pick up only.
Rear Hatch tailgate in Yellow - Comes with Reverse tail light covers. . . No dents or dings, but does have the paint chipping off which might be a good thing. I don't know anyone else on the forum with a yellow hatch anyways. . . $100
P30 Clutch, Flywheel, and Pressure Plate - $75 - The clutch has a fairly good amount of meat left. I would say about 75%
B16a Intake manifold - $100
Steering Wheel with Airbag - $50
Passenger Airbag - $50
SRS Computer, all the wires to connect to passenger and driver's side - $25
Front Carpet, pretty dirty, but cleanable I think it is dark grey, not sure - $50
Rear interior sides black - had been cut for upper tower strut bar -
- $35
TRW Torino Four point harness in red with blue strap pads. This is the one with a single latch going to the rear versus the dual. - $40
Guys, once I get a camera I will have pictures of everything here. The engine is still together and in my car.
P28 Chipped - $150
- $35TRW Torino Four point harness in red with blue strap pads. This is the one with a single latch going to the rear versus the dual. - $40
