APEXi afc Neo in oc $330 bnib
Old Mar 23, 2008 | 12:22 AM
rcantu's Avatar
Default APEXi afc Neo in oc $330 bnib
brand new guys. just decided not to use it. it's still sealed.
The A'pexi AFC NEO is a NEW Addition to the US Line Up. The Apex AFC NEO features and Updated LCD Color Screen with real time vehicle information displays. The AFC NEO replaces the Apex AFC2 and the Apex VAFC2. The APEX'i NEO Works on Japanese American and European Fuel Injected Vehicles. The Apex AFC NEO Air / Fuel Controller is the easiest way to modify the Fuel Maps and Control Vtec from one handheld unit. The On-Screen Display is easy to navigate and modify. The VTEC Controller allows the user to modify the fuel curve at 24 adjustable increments as well as change the VTEC Engagement Point. Most cars will see a 10-20 increase in horsepower. Installs in 1 Hour.
Features of the Apex AFC NEO Controller Include:
Fuel Control
Adjust Fuel Delivery Range of +50% to -50% up to 1% Step Increments in 100 RPM Increments
Unmatched Fuel Control, Richen or Lean out the Fuel Mixture when Vtec Engages
Vtec Control
Adjustable Vtec Control for RPMs, Throttle Angle, Upshift / Downshift, Engine Speed
Vtec is Adjustable in Increments of 100 Rpm for a Total of 24 Throttle Based Points
Not Intended for use with i-Vtec Equipped Engines (2002-2006 Models)
For Vehicles with Vtec Engine Swaps, The VAFC-2 Can be used to Activate V-TEC for a Non-Vtec ECU.
Monitoring Functions / Apex VAFC 2 Updates
Digital Real Time Display of RPM Gauge Throttle Position, MAP Pressure, and Knock Sensor Monitor, Battery Voltage, Correction %
Control Panel alters when when Lo / Hi Vtec Cam Engages
The AFC NEO has password Lockout and Retains Memory of Settings if the Battery is Disconnected
Old Mar 23, 2008 | 08:55 PM
rcantu's Avatar
Default Re: APEXi afc Neo in oc $330 bnib (rcantu)
hot day bump
Old Mar 24, 2008 | 07:24 AM
rcantu's Avatar
feel free to make offers but crazy lowballs will be ignored
Old Mar 24, 2008 | 08:54 PM
rcantu's Avatar
Old Mar 26, 2008 | 08:03 AM
rcantu's Avatar
bump
Old Mar 27, 2008 | 07:32 AM
rcantu's Avatar
Old Mar 28, 2008 | 02:23 PM
rcantu's Avatar
bump
Old Mar 28, 2008 | 03:56 PM
shillsdc2's Avatar
BUMI IT TTMFT!!
Old Mar 29, 2008 | 09:28 AM
rcantu's Avatar
Default Re: APEXi afc Neo in oc $330 bnib (shillsdc2)
thanks.....
Old Mar 31, 2008 | 08:02 AM
rcantu's Avatar
offers welcome but lowballs not. this is brand new in box and unopened.
Old Apr 2, 2008 | 06:45 AM
rcantu's Avatar
brand new guys.
Old Dec 13, 2008 | 12:10 AM
bryantran84's Avatar
bump if u stil have it then call me at 714-722-5088 thanks
Old Dec 13, 2008 | 03:02 AM
fc3srx729's Avatar
bump...
TitanMotorsport
Performance
Jun 10, 2013 02:54 PM
3vilMonkey!
23
Apr 1, 2005 05:02 AM
mr2
Oct 21, 2001 03:23 AM
