Rings Seating and Burning Oil
Old Mar 22, 2008 | 11:09 PM
hailchristian's Avatar
Default Rings Seating and Burning Oil
Alright..so..i have had so many problems with this dohc zc but its finally running for the most part..
it is smoking a bunch. White/grey smoke when i give it some gas. It doesn't seem to have any smoke as the rpms drop. The guy i bought the engine from told me new rings, rods, and bearings.
So my assumption would be that rings need to seat and it will burn oil and smoke until they seat, but im not sure on that..can anyone confirm?
I have about 225 Miles on the engine so far. Ive been making sure to keep the oil in between the dots and making sure that its not over heating or anything. How long until this smoke stops? Someone told me 1K miles for the rings to seat but IDK about that.
Figure i might as well post a picture to ***** out my car and show the kinda smoke im dealing with
Go easy on the gaytazzas...they are getting replaced after the car is running good.
Modified by hailchristian at 12:21 AM 3/23/2008
Old Mar 22, 2008 | 11:21 PM
89GSRHATCH's Avatar
Default Re: Rings Seating and Burning Oil (hailchristian)
Did he tell you what kind of rings he used because if he just used stock ring they should have set already it shouldent smoke for long unless he dident built the bottom end right did he gap the rings ??
Old Mar 22, 2008 | 11:22 PM
89GSRHATCH's Avatar
Default Re: Rings Seating and Burning Oil (89GSRHATCH)
and that looks like blow head gasket smoke
Old Mar 22, 2008 | 11:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89GSRHATCH &raquo;</TD></TR><TR><TD CLASS="quote">Did he tell you what kind of rings he used because if he just used stock ring they should have set already it shouldent smoke for long unless he dident built the bottom end right did he gap the rings ?? </TD></TR></TABLE>
He didn't really say anything besides new rings rods and bearings. He said the engine would run, and it didnt because he sold it to me with a D15 crank gear on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89GSRHATCH &raquo;</TD></TR><TR><TD CLASS="quote">and that looks like blow head gasket smoke </TD></TR></TABLE>
new head gasket, no oil in the water/water in the oil..i think im fine there.
Old Mar 22, 2008 | 11:25 PM
89GSRHATCH's Avatar
i dont want to be negitive but i think he screwed you as far as the motor goes does the oil look milky at all or is it just staight oil burning are you going threw oil ??
Old Mar 22, 2008 | 11:26 PM
89GSRHATCH's Avatar
iam thinkin he dident know how to rebuild a motor because it should not smoke that much even for a first fire up on a brand new motor i build them for a living and they should not do that
Old Mar 22, 2008 | 11:30 PM
it's burning oil...forsure..Ive been checking and filling constantly.
the oil is not milky at all. It goes from being clean oil. to dirty oil. Which is what its at now, dirty oil.
He said the motor had about 50K miles on it to begin with so IDK...i really have no money left and im sure as hell not going back to my d15b1 thats in the back yard.
Lets say the rings are messed up? how much would a shop charge to make everything good in the hood?
Old Mar 22, 2008 | 11:37 PM
89GSRHATCH's Avatar
its hard to say might be cheaper to just get another motor
Old Mar 22, 2008 | 11:38 PM
89GSRHATCH's Avatar
you can find dohc zc motors for around 5 550 and that well be cheaper then doing a ring job
Old Mar 23, 2008 | 12:16 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89GSRHATCH &raquo;</TD></TR><TR><TD CLASS="quote">you can find dohc zc motors for around 5 550 and that well be cheaper then doing a ring job </TD></TR></TABLE>
X2 and fo real y0!
Old Mar 23, 2008 | 06:18 AM
Black4thgenEF's Avatar
Default Re: Rings Seating and Burning Oil (SIred91)
If that smoke is as white as it looks your head gasket is toast. My old d16a6 used to do that on start up once in a while, a full year before the head gasket got bad enough to start mixing the oil and coolant...
Old Mar 23, 2008 | 07:03 AM
Twisted Image's Avatar
Default Re: Rings Seating and Burning Oil (Black4thgenEF)
Have you noticed any oil in your intake? Check your throttle body for oil.
Check the PCV valve if you find oil in your intake manifold
Check compression Hot, then check it warm...this will tell you alot about the rings and head gasket. A leak down test wouldnt be a bad idea too
I know it took about 100 miles for my CP rings to seal fully. It smoked that bad for only about 2 miles though then it was just light smoke when stopped I could see it and hard accel/shift.
Old Mar 23, 2008 | 10:25 AM
Default Re: Rings Seating and Burning Oil (Twisted Image)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twisted Image &raquo;</TD></TR><TR><TD CLASS="quote">Have you noticed any oil in your intake? Check your throttle body for oil.
I know it took about 100 miles for my CP rings to seal fully. It smoked that bad for only about 2 miles though then it was just light smoke when stopped I could see it and hard accel/shift.</TD></TR></TABLE>
my old pcv valve was shot. I replaced it last night.
Old Mar 23, 2008 | 09:25 PM
im hoping its the head gasket....that would be a nice fix..compression test will bear the results.
Old Mar 25, 2008 | 07:15 PM
Alright....finally got a compression test
results are as follows
Dry
1 160
2 160
3 160
4 160
Wet
1 170
2 160
3 160
4 170
Old Mar 25, 2008 | 07:22 PM
~sp33~'s Avatar
EFB055
Hmm pretty consistent. It's odd that the smoke looks so white. Are you using coolant at all?
Old Mar 25, 2008 | 08:26 PM
Default Re: (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">Hmm pretty consistent. It's odd that the smoke looks so white. Are you using coolant at all?</TD></TR></TABLE>
its got 1/4 anti freeze...rest is water
Modified by hailchristian at 11:01 PM 3/25/2008
Old Mar 26, 2008 | 06:42 AM
~sp33~'s Avatar
EFB055
I meant, is it going through coolant. Like do you have to keep replacing it.
Old Mar 26, 2008 | 08:04 AM
oh...that makes more since..i was like..wtf dont all civics use coolant to cool the engines...
anywho....isnt really lowering at all..coolant level has been the same since i filled it.
Old Mar 26, 2008 | 09:30 AM
whiteknightef's Avatar
Default Re: (hailchristian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hailchristian &raquo;</TD></TR><TR><TD CLASS="quote">oh...that makes more since..i was like..wtf dont all civics use coolant to cool the engines...
anywho....isnt really lowering at all..coolant level has been the same since i filled it.</TD></TR></TABLE>
so you admit you had to fill it? Im confused?
I think its a combination of the two things. The PVC will suck as much oil when faulty as bad rings will. The white smoke is definately water. Oil doesnt make that much smoke. Also your oil could be getting dirty through break-in and through burning dirty coolant from the block. I think you should check the head gasket! Did you say you already changed the head gasket or did the guy you bought it from do it? I wouldnt trust him if he says its a new gasket.
Replace the cheap stuff!
Old Mar 26, 2008 | 03:17 PM
Default Re: (whiteknightef)
well..it had a leak in the cooling system..so i had to drain it to fix the lower hose then re filled and bleed..so yes
PVC was bad and replaced it so that could stop the burning oil problem..ill check into that, havn't checked my oil since the oil change.
I put the head gasket on, this was back like a week after i got the engine..didn't know what i was doing, probably messed up something. I also used a cheap auto zone gasket. I will go to the acura dealership and get a genuine this time.
thanks for all your help..ill change it this weekend and let everyone know what happens
Old Mar 26, 2008 | 08:41 PM
i just checked my oil..it isn't burning nearly as much as it was with the old pcv valve.
thats good news.
Old Mar 26, 2008 | 09:19 PM
zcmotor's Avatar
i went into autozone and asked a worker there and he said white smoke is Coolant being burned. so doing a leak down test would tell you exactly what's causing it. I do too have the same problem and i dont want to go ahead and change the head gasket if that's not the problem. If you fix it let me know what was wrong that way ill know what could be wrong with mine
Old Mar 26, 2008 | 09:21 PM
Default Re: (zcmotor)
lol...your the same guy thats on my zcr post...
im going to an OEM head gasket this weekend..see whats going on on the block as well as replace the gasket
ill post results forsure.
