air conditioning problem
Old Mar 22, 2008 | 10:34 PM
cdfran's Avatar
Default air conditioning problem
ok i just finished pumping freon in my car but i ran into a few problems and i hope ya can help...
first: the compressor whines when i rev up the engine and compressor doesnt cycle
second: the compressor clutch stops when i turn on the headlights... please help if you can
Old Mar 23, 2008 | 12:54 AM
YeuEmMaiMai's Avatar
Default Re: air conditioning problem (cdfran)
proper way to recharge the system (to ensure correct refigerant and oil amt) is to
1. evacuate the system
2. see if it holds a vaccum for at least 8 hours if not, repair leaks and replace accumulator/dryer and test again. (you only need to replace the acumulator/dryer once)
3. recharge using proper amt of R134a and PAG oil.
if the system is overcharged by a significant amount, the high pressure switch will prevent the compressor from engaging.
Old Mar 23, 2008 | 08:51 AM
cdfran's Avatar
cool ill measure the system see thanks
Old Mar 23, 2008 | 09:22 AM
hondadude's Avatar
The next time you are under the hood, look around for the little sticker that says WHAT YEAR the Accord is
Old Mar 23, 2008 | 10:11 AM
cdfran's Avatar
im pretty sure its a 94 cause i had to convert it to a 95 compressor because the ac lines were touching the header
R_ACE1
Honda CR-V & Element
Sep 12, 2013 10:28 AM
marqoid
10
Jun 28, 2013 04:41 PM
Dres
Mar 15, 2011 05:43 AM
FamilyGuy
Nov 23, 2008 05:28 PM
maivla01
May 31, 2006 10:32 AM
