squealing sound coming from driver rear side
Old Jul 9, 2002 | 04:44 AM
sidwin's Avatar
New User
Default squealing sound coming from driver rear side 94 Honda Accord Ex Coupe
I am having an intermittent squealing sound coming from the rear driver side. I can't figure out if it is the wheel bearing or the caliper sticking. I haven't ever heard of a front wheel drive car having a rear bearing having to get replaced. My car is a 94 ex accord with 199,300 miles on it. The squealing sound is very intermittent. I thought if it is the calipers then when i tap my brakes it should uncompress the brake piston. But that isn't the case. it sounds like metal on metal. I check the pads and I still have 35% left.
Thanks,
Sid
95 Single Turbo Supra 574 rwhp www.sidwin.com/supra.htm
94 Honda Accord Ex Coupe 199,300 miles and still going
[Modified by sidwin, 1:44 PM 7/9/2002]
[Modified by sidwin, 1:46 PM 7/9/2002]
Old Jul 9, 2002 | 10:08 AM
CivicNewbie's Avatar
Default Re: squealing sound coming from driver rear side 94 Honda Accord Ex Coupe (sidwin)
Have you checked the metal plates behind the brake rotors?
Old Jul 9, 2002 | 10:14 AM
sidwin's Avatar
New User
Default Re: squealing sound coming from driver rear side 94 Honda Accord Ex Coupe (CivicNewbie)
no i don't think it is the metal vent plate because if that was the case, the squeal would not be intermittent.
thanks,
sid
95 single turbo supra 574 rwhp
94 honda accord ex coupe
Old Jul 9, 2002 | 10:45 AM
YeuEmMaiMai's Avatar
may be just old age high milage syndrome
Old Jul 9, 2002 | 11:05 AM
sidwin's Avatar
New User
Default Re: squealing sound coming from driver rear side 94 Honda Accord Ex Coupe (YeuEmMaiMai)
WHATEVER! A car doesn't just start making metal on metal sound just because of old age. Something is obviously wrong.
sid
Old Jul 9, 2002 | 11:08 AM
DUFFY's Avatar
Have you tried to lube the calipers or the bearing?
Old Jul 9, 2002 | 11:16 AM
oh really? are you sure? many cars squeak and rattle at that high milage..... you sure didn't want to take that other guy's advice and he just may be right something inside your brake drums or dragging on your calipers (if you have them). I had a car where the brake adjuster broke and it made the same noise as you describle... if fell to the bottom of the drum
Old Jul 9, 2002 | 11:20 AM
DUFFY's Avatar
me too
Old Jul 9, 2002 | 11:30 AM
sidwin's Avatar
New User
I have a 94 EX accord. it is DISC brakes all the way around. no drums to check. I already checked the pads. The shims are fine. That is why i am narrowing it down to caliper rebuild or bad bearing.
thanks,
sid
Chanb0b
Suspension & Brakes
Jan 3, 2016 03:29 PM
JerseyGirl474
13
Feb 19, 2013 09:22 PM
masterchief1123
Nov 5, 2011 10:41 AM
96AccordExCpe
Jun 17, 2003 07:06 PM
