Shaking Problem...Out of ideas
Well my car shakes when ever I accelerate at low rpms stops around 3500-4000. Doesn't shake when Im cruising. I just replaced both my tie rod ends and got an alignment done. Ive replaced axles before both of them multiple times and then bought brand new ones.
Any other ideas? Im thinking the only thing left is inner tie rods.
Have you tried the mid-shaft??? I have a bad one the seems to be the problem with my low rpm shakes...leaks grease and all lol.
Warp rotors
loose bolts
bushings
bad tires
bent rims
Honda???
j/k
Warp rotors
loose bolts
bushings
bad tires
bent rims
Honda???
j/k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 »</TD></TR><TR><TD CLASS="quote">ight. Is the intermediate shaft the same through all integras bc I have a jdm itr swap in my LS</TD></TR></TABLE>
yea they should be the same on all b series. I would get someone elses opinion tho just to make sure.
Acurazor
Suspension & Brakes
Jun 26, 2009 08:47 AM
whitelightning
May 5, 2004 12:25 PM
DC 2
May 2, 2004 09:03 PM
