Ran car at track now, issues with reverse. Linkage bent?
I ran one pass and parked my car to let it cool down. When I got ready to run again I couldn't get it into reverse. I had to hit the shifer to get it to move. Every gear is smooth as butter, but when you park and put the clutch in and shift from reverse to 5th it feels a little notchy. Is it possible I bent the linkage? Its a little odd that I only have issues with reverse. Also the clutch is fine, so i know its not that. Any way this issue was enough that I only made one pass.
Has this happened to anyone else?
Thanks
Thanks
Has your tanny ever been taken apart cause if it has you need to make sure all the sliders are in the right position, these trannies are kind of finiky and everything needs to be right on the money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A L I A S »</TD></TR><TR><TD CLASS="quote">tranny fluid low?</TD></TR></TABLE>
No its good I chaged it about a week ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extremevtecracing »</TD></TR><TR><TD CLASS="quote">Has your tanny ever been taken apart cause if it has you need to make sure all the sliders are in the right position, these trannies are kind of finiky and everything needs to be right on the money.</TD></TR></TABLE>
It has been a a couple years since the tranny was taken apart. I launched at 5k on drag radial, but preloaded. No wheel hop or wheel spin, so it doesn't really make since.
ZCRexSnglecamV
12
Jan 5, 2007 12:47 PM
