integra da car wont start need help asap
ok so it was real late my car was on empty (really low). so i just went home and parked. woke up in the morning noticed car was on a real big slant and car wont start. i go to get some gas around 10$ and car still wont start. i talked to a few friends and they told me to turn the key on(not turning over the engine) and letting the fuel pump run (about 15 times). still wont start i tryed to jump start and push start nothing. new battery/terminals. spark plugs/wires are fine. can any one help me out??
well i recently moved so i do not have my tools so its pretty hard to check things without tools. i pushed in the injectors and tryed to spin them a little bit of fuel came out so im assuming fuel is comming through today im going to put sum fuel injector cleaner in hopefully better story. wat else can this possibly be its trying to turn over but can just chachachahchahcha
Did you check to see if you were getting spark, pull a plug wire and attach a plug to the end, then ground the threading on the plug to see if its sparking... some times running fuel pumps dry can fry the pump. they are cooled by the fuel..
JDM Freakk
Jun 21, 2011 05:36 PM
