EK3 (D15Z6) Engine died ! B18C Time ??
The engine in my 1997 EK3 Hatch has seized the bottom end
The head is turning fine, but the bottom end is solid
The engine is currently a D15z6 vetec-e (enhanced performance ! Apparently !!!!) it is a Europe only model so you guys don't get it in that states
But my question is what do i put in now ???????
I have been offered -
D15z6 (55k miles) for £170
D16z6 (56K miles) and ECU for £200
B16a2 (85k miles),gearbox, ECU, Wiring harness and gear selector (the only thing missing is driveshafts they have already been sold ) for £430 (i think i could still get this a little bit less)
and
B18C (76k miles), LSD Gearbox,ECU,Wiring harness,driveshafts and gear selector (no keys do i need them ??) for £1250
I am thinking to go for the B18C
Would i need any other bits ?
But what do you guys recommend ?
I use the car mainly for the road but may do the odd day at the track or strip
Cheers for any help !!
R883
and
R883
yeah i think that is what i am going to do
Do i need any other bits ?
Engine, LSD Gearbox,ECU,Wiring harness,drive shafts and gear selector
From what i have read i think i dont
Also my car is OB2 and the teg is OB2b
Will this be ok ?
Will this be ok ?
Ok so further to my reading i am now sure if i need to go from obd2 to obd2b then i need a conversion harness or a obd2 ecu.
The donor car that i am getting the enginge from is a 1998 UKDM Integra Type R
What i want to know ( and be re assured) is
What other bits can i get from it ?
I was thinking
Rear Brakes - I would need the trailing arm with discs + calipers and brake lines (flexi pipes ?)
Front Brakes - Can i just use the the calipers on my exsiting hubs ?
Or do i need the ITR hubs ?
Cant really find any info on this
And i take it that if i fit these i will need the master clyinder and the prop valve from the ITR ?
Also do the UKDM ITR`s have the same drive shafts ? or do i need a 5 lug conversion ?
Cheers for any help
R883
I was thinking
Cheers for any help
R883
