Sohc Vtec swap.. Which mount to use?
this seems like a dumb question but my cousin is doing an obd1 sohc vtec swap and conversion and the stock d16z6 driver side mount does not line up with the crx mount brackets, but in my 91 hatch it is the d16z6 driver side mount that we used... Anybody ever ran into this problem?
Someone is mistaken. The obd0 stock sohc mount from your ef must be bolted to the side of the engine and into the chassis. The obd1 mount can't be used
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician »</TD></TR><TR><TD CLASS="quote">Someone is mistaken. The obd0 stock sohc mount from your ef must be bolted to the side of the engine and into the chassis. The obd1 mount can't be used</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sitenabe »</TD></TR><TR><TD CLASS="quote">so if im installing a Sohc vtec into my 91 civic si, i can use the stock mounts</TD></TR></TABLE>
Yes
Yes
dr_latino999
18
Oct 20, 2006 12:08 PM
dr_latino999
Welding / Fabrication
Jul 3, 2006 07:16 PM
Phazetwo Mike
Jul 31, 2005 01:14 PM
3.8turbo
May 26, 2004 07:48 PM
