What MAP sensor 4 DX to SI head ??
Does it matter what MAP sensor you use when putting a D16A6 head on a D15B2 ?? Does it HAVE TO BE a SI MAP sensor or can I use the DX one ??? And is it true, about the timing always being off half a tooth, unless you get an adjustable cam gear ?
the map sensor are the same so you can keep which ever you already have. as for the timing, i guess its true about it being a teeth off or something can someone else verify
Well I am running the DX map sensor with a ZC engine, and many B16A engines are running it too. Makes no difference till you start to boost.
Ef4doorwagon
Mar 18, 2014 12:35 PM
crxh22project
Jan 28, 2005 07:00 PM
