Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spring free length for koni sleeves
Old Mar 21, 2008 | 10:11 PM
ronald55555's Avatar
Default Spring free length for koni sleeves
I have a set of koni sleeves that i want to put on, but i notice they are quite a bit shorter than the GC sleeves. The koni sleeves are about 4" long, which is pretty much same as the GC front. For the rear the koni sleeve is significantly shorter than the GC. I am just wondering if there are anyone here running koni sleeves, and what rate & length spring do you run. For people running GC sleeves and 7" spring, how far up is your collar(measured from the circlip). Anyone know what length spring i should be running so that the lower perch is set approx 2" up from the circlip? thanks
setup:
96-00 civic
450lb front
400lb rear
Old Mar 22, 2008 | 02:59 AM
beanbag's Avatar
Default Re: Spring free length for koni sleeves (ronald55555)
I think this is where you use the power of "math" to solve your problem.
You need to know your LCA motion ratio and the weight of the rear of your car
spring compression = corner weight/motion ratio / 400
spring compressed length = free length - compression
then measure downwards from the top hat
Choose the free length based on how much you want the car to be lowered
mikzsan
Suspension & Brakes
15
May 8, 2012 02:44 PM
itr1244
Jan 22, 2012 06:32 PM
saltypants
May 3, 2007 03:14 PM
DougNuts
Suspension & Brakes
11
Jun 12, 2006 09:47 AM
Corruption
May 18, 2005 10:57 AM
