16x8 fit on a Ef
Old Mar 21, 2008 | 04:16 PM
ef9robert's Avatar
Default 16x8 fit on a Ef
Looking for another set of shoes, and wonder if this would work or not.
Old Mar 21, 2008 | 04:26 PM
89hatcher's Avatar
it will work depending on the offset...16x8 is really wide...if your going to run a low offset be prepared to roll your fenders...also it depends on the size of tire you use also...
Old Mar 21, 2008 | 09:01 PM
my91tealhb's Avatar
Default Re: (89hatcher)
Might, rub depends how low you are. I have 16x7 38 offset and 205/45/16 and it rubs. I have coilovers and I have to keep it kind of high to avoid rubbing. Maybe if you go with a smaller tire?
Old Mar 21, 2008 | 11:31 PM
89hatcher's Avatar
Default Re: (my91tealhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my91tealhb &raquo;</TD></TR><TR><TD CLASS="quote">Might, rub depends how low you are. I have 16x7 38 offset and 205/45/16 and it rubs. I have coilovers and I have to keep it kind of high to avoid rubbing. Maybe if you go with a smaller tire? </TD></TR></TABLE>
i almost have the same tire and rim combo and mines rub hella bad...i had to raise the car a little and roll my fenders...
Platinum.Skillz
Oct 31, 2007 11:52 AM
EJ1chevelle
Oct 20, 2007 08:14 AM
Shmaa
Jun 2, 2006 02:48 PM
95BG33PGSR
Dec 10, 2005 07:45 PM
Frog
Feb 19, 2004 07:56 PM
