HELP! I cant install my Apexi WS2 catback exhaust
Old Mar 21, 2008 | 12:15 PM
iwantturbo's Avatar
Default HELP! I cant install my Apexi WS2 catback exhaust
Well, I bought a new Apexi WS2 catback exhaust, but the problem is my catalytic converter is too short. I had a problem with my OEM cat before, so i got it replaced with a Magnaflow cat that i got welded on. Problem is, the Magnaflow cat I have turns out to be a lot shorter than the OEM cat. Thus, fitment with the catback will be a few inches off.
Do I have any alternatives besides getting a new catalytic converter? I looked/called a bunch of junkyards today but no one has them.
Old Mar 21, 2008 | 12:32 PM
BYAAH85's Avatar
Default Re: HELP! I cant install my Apexi WS2 catback exhaust (iwantturbo)
go to a muffler shop and have them take care of it
rEnZ94tEgGy's Avatar
just go with your stock cat or try another brand cat...
Old Mar 21, 2008 | 01:05 PM
iwantturbo's Avatar
Default Re: HELP! I cant install my Apexi WS2 catback exhaust (BYAAH85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BYAAH85 &raquo;</TD></TR><TR><TD CLASS="quote">go to a muffler shop and have them take care of it</TD></TR></TABLE>
what would they do? the closest decent muffler shop is about 50 minutes away from where i live. i dont wanna make the drive finding out they cant do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rEnZ94tEgGy &raquo;</TD></TR><TR><TD CLASS="quote">just go with your stock cat or try another brand cat...</TD></TR></TABLE>
i dont have my stock cat anymore. and i dont wanna buy another catalytic converter if i dont have to since i just spent 420 on the ws2
Old Mar 21, 2008 | 01:15 PM
nate_2k5's Avatar
the muffler shop will just weld in a length of pipe to connect to the cat. check around, even a lot of little hole in the wall small town shops do exhaust work
Old Mar 21, 2008 | 02:47 PM
i suggest you move to a big city like the man streets of L.A or do what nate_2k5 said...
Old Mar 21, 2008 | 03:02 PM
iwantturbo's Avatar
Default Re: HELP! I cant install my Apexi WS2 catback exhaust (nate_2k5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">the muffler shop will just weld in a length of pipe to connect to the cat. check around, even a lot of little hole in the wall small town shops do exhaust work</TD></TR></TABLE>
thanks for the input guys.. nate_2k5 i was actually thinking that... but i was wondering, wud they be able to weld a pipe between the headers and the catalytic converter?
Old Mar 21, 2008 | 03:28 PM
iwantturbo's Avatar
I made this diagram... is this possible? a welded pipe between the headers and the catalytic converter to make up for the original length on an OEM cat. and the rest would be the bolt on exhaust. success?
Old Mar 21, 2008 | 03:42 PM
emotionisdead's Avatar
Very Emergency!!
blox adjustable test pipe!! takes care of all you problems.
anyway, it would be okay to weld before or after the cat. I just wouldn't cut into the actual apex piping.
Old Mar 21, 2008 | 03:44 PM
iwantturbo's Avatar
Default Re: HELP! I cant install my Apexi WS2 catback exhaust (emotionisdead)
naah no test pipes... i dont want any trouble when getting my car inspected and also cause I don't want my exhaust to be loud.
Old Mar 21, 2008 | 04:42 PM
nate_2k5's Avatar
its easier to weld it in between the b pipe and cat.
Old Mar 21, 2008 | 04:45 PM
VTEC_PRODUCTION's Avatar
if your really that lazy then go to the auto store pick up that diameter pipe, cut, and use some clamps
Old Mar 21, 2008 | 05:44 PM
jaypanEG6's Avatar
Default Re: HELP! I cant install my Apexi WS2 catback exhaust (VTEC_PRODUCTION)
cat or no cat... apexi ws2 catback will not be LOUD.
Old Mar 21, 2008 | 06:00 PM
supracrx's Avatar
muffler shop can take care of it for sure....
i had a rsr exmag just the muffler alone for a 4 door, used a comptech midpipe, and they had to custom some stuff since it was not for a 2 door, and for some reason the resonator hung very low so they cut that section and just welded another pipe in its place.
Old Mar 21, 2008 | 06:31 PM
90_EX_Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwantturbo &raquo;</TD></TR><TR><TD CLASS="quote">
you know what would fit in that area? a flex pipe. that is if you want one. if not, do what everyone else says, just get a shop that does some welding to put a pipe there.
Old Mar 21, 2008 | 07:41 PM
iwantturbo's Avatar
thanks for all the input guys... i really appreciate it. im just gonna go take the trip to the muffler shop tomorrow morning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">its easier to weld it in between the b pipe and cat.</TD></TR></TABLE>
and yeah i asked my cousin who is a genius and he said the same thing. he said the headers are made of a material that isnt good to weld on.
Old Mar 21, 2008 | 08:01 PM
iwantturbo's Avatar
so i made this new diagram and i think this is how its gonna turn out. hopefully it works!!
Old Mar 21, 2008 | 08:52 PM
Presto800's Avatar
Wow I have the exact same problem down to the WS2 and everything. I bought my car a couple months ago and got under it a couple weeks ago to do the same thing and found out i had an aftermarket cat that was too short.
I was going to just buy a test pipe, but if welding a piece is cheaper, I'd like to know if its possible to cut and weld the thick gnarley piping apexi uses? cause they're going to have to cut off the flange on the piping to do weld.
Old Mar 21, 2008 | 09:06 PM
Sumslapper's Avatar
Year 3030
Default Re: (Presto800)
why dont you just find a oem cat. I had a aftermarket one and it blew all of its guts out and rattled. I just wouldnt want to hack up the apexi.
Old Mar 21, 2008 | 09:15 PM
iwantturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Presto800 &raquo;</TD></TR><TR><TD CLASS="quote">Wow I have the exact same problem down to the WS2 and everything. I bought my car a couple months ago and got under it a couple weeks ago to do the same thing and found out i had an aftermarket cat that was too short.
I was going to just buy a test pipe, but if welding a piece is cheaper, I'd like to know if its possible to cut and weld the thick gnarley piping apexi uses? cause they're going to have to cut off the flange on the piping to do weld.</TD></TR></TABLE>
You like my diagrams? haha... I'm going to the muffler shop tomorrow so I'll let you know how it goes. I was thinking the same thing regarding the thick *** Apexi piping (which is good) whether they would be able to cut it or whatever.
Old Mar 21, 2008 | 09:18 PM
iwantturbo's Avatar
Default Re: (Sumslapper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just find a oem cat. I had a aftermarket one and it blew all of its guts out and rattled. I just wouldnt want to hack up the apexi.</TD></TR></TABLE>
i went to a ton of junkyards today and called a bunch of people from different honda forums, including craigslist. unfortunately no one had one that they were selling. the aftermarket cat i have right now is a magnaflow and hasnt given me problems in the 2 years ive had it.
Old Mar 22, 2008 | 10:34 AM
iwantturbo's Avatar
Default Re: (iwantturbo)
so i just got back from the muffler shop... they didnt cut the flanges off the apexi piping. The piping is so thick that i think doing so would have just damaged the piping. they just welded another pipe onto the b-pipe and that was that. it was a real tough job though and something you needed a lift to do. not something you can just pull off in 2 hours in your garage. i paid $100 dollars by the way if anyone is curious and it took about an hour an 20 minutes.
Old Mar 22, 2008 | 10:59 AM
MopdiT's Avatar
So how do you like the muffler so far...? $100 is a bit much just for an extension on piping...!!!
Old Mar 22, 2008 | 11:36 AM
damn man! you got rapped. 100 bucks for a piece of pipe that only cost about $10? what do they charge per hour, $70 dollars? i feel for you man, $100 was too much.
Old Mar 23, 2008 | 07:26 AM
iwantturbo's Avatar
Default Re: (90_EX_Civic)
haha nah. it was also for the installation of a full catback exhaust.
