h22 accord swap help
Old Mar 20, 2008 | 06:35 PM
LiL JoN's Avatar
Default h22 accord swap help
i just got a 97 accord with a jdm h22a in it. The wire harness is hacked to **** so i picked up a stock f22 harness, has no distributer or injectors but has a obd2-obd1 conversion harness with p13 ecu.
i need to know if the obd1 h22 injectors and dist will bolt up to the f22 harness or can i use f22 injectors and distributer on the h22 motor.
help asap please.
Old Mar 20, 2008 | 06:40 PM
TheMuffinMan's Avatar
He knows where you live!
You cannot use f22 injectors, it'll run like absolute ***.
Same with the dizzy.
Old Mar 20, 2008 | 07:15 PM
LiL JoN's Avatar
Default Re: (TheMuffinMan)
the distributer i have is a TD-60U. Its all hacked and doesnt have the clips on it. Could the f22 harness bolt up to that dist?
Old Mar 20, 2008 | 07:20 PM
Should, a lot of the h22 swap people modify their F harness to work.
You have to swap the ECU pins, add on a couple wires for sensors and you're good.
Check out one of the H22 swap threads in the Accord FAQ
Old Mar 21, 2008 | 05:10 PM
Hella_Fresh's Avatar
bump for more. We found a harness but now we have one clip extra on the pass side shock tower?
Old Mar 21, 2008 | 09:22 PM
An accord harness?
I think I've got like 3 dangling around lol.
It's near that big bundle right around the tower right?
Old Mar 21, 2008 | 09:50 PM
Yea it right where the bundle is. I was thinking it might be cause the accord harness was from a automatic.
Old Mar 22, 2008 | 11:21 AM
LiL JoN's Avatar
Default Re: (Hella_Fresh)
up help
Old Mar 22, 2008 | 04:31 PM
Default Re: (LiL JoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiL JoN &raquo;</TD></TR><TR><TD CLASS="quote">up help</TD></TR></TABLE>
Old Mar 23, 2008 | 12:02 PM
ttt
Old Mar 23, 2008 | 03:47 PM
LiL JoN's Avatar
95accord8966
Nov 22, 2007 04:05 PM
hondatuningboi96
Jun 7, 2006 03:58 AM
4DRPIMPIN
Dec 23, 2003 07:46 AM
Bowlergi21
Aug 22, 2003 04:50 PM
