building an f23 non-vtec... need info on head and deck heights.
Old Mar 20, 2008 | 05:47 PM
AK_CRX's Avatar
Default building an f23 non-vtec... need info on head and deck heights.
Kindof an odball setup I'm working on... I am mounting an f22a1 head onto an f23 bottom end. The only thing I have a question on is the belt... anyone have suggestion or know which belt would work? If the f23a is the same deck height as the f22a then an f22a belt will work perfect. but if the f23 deck is taller than an f22a I may need a slightly longer belt than the f22a's. I know the f23 belt wont work since the vtec head is taller than the f22a's nonvtec head... So any insight would be very helpfull thanks in advance.
Old Mar 21, 2008 | 05:35 AM
BlkChryKord's Avatar
Copied from here -
F22 block = 8.643
F23 block = 8.643
https://honda-tech.com/zerothread?id=1232811
lance92
Jun 20, 2010 02:47 PM
Civiclized
Mar 22, 2010 02:45 AM
oldschoollove
11
Sep 16, 2009 09:08 AM
AK_CRX
Mar 20, 2008 05:45 PM
Patrickchampagne2006
Mar 12, 2007 11:54 AM
