TW/FS/FT: 93 HOnda prelude Si w/H22a, Clean Title
TW/FS/FT: 93 Honda Prelude Si with JDM H22a. CLEAN TITLE, PINK IN HAND
IM really looking for a trade, maybe a sell PRICE: 6000. Im really interested in owning an Civic hatchback (EF, EG, EK), 99-2000 Civic Si(electron blue), 94-95 Integra
Guys, I’m just here thinking about selling/trading my car. Let see if it gets any interest
So the car is black exterior, grey/black interior. Paint is not too bad. It has sun spots on the sunroof and trunk, that’s all. But keep in mind this is OEM paint. Just to let you know of the bat, I’m a technician at Honda, so this car is keep up As best as possible.
Motor:
JDM H22
Cylinder head: New OEM valves, NEW OEM valve seals, Valve Angle Job, and Decked HEAD Surface
Block: New OEM pistons, OEM Head bolts, Cylinder Honed, ALL internals Balanced, Crankshaft Micro polished, Decked block surface.
Basically all OEM! Stock Air box
Generic Header
Apexi N1 Catback Exhaust
Recently replaced Catalytic Converter
H23 Distributor and External coil
HONDA 10w-30 Conventional
Custom mounted KOYO Aluminum Radiator
HONDA BLUE COOLANT ONLY
Power Steering Still there
A/c Removed
Cruise Control Removed
Drive train:
H23 transmission
Exedy stage 2 Clutch
OEM flywheel
Generic Billet short shifter
HONDA NEW MTF ONLY!
Stance:
Koni Adjustable Damper Sport Shocks
Ground Control Coil over (koni Specific)
Generic UCA camber kit
Megan racing Rear Toe Control Arms
Front and rear Nuespeed sway bars
Spoon Upper Tie Bar
Exterior:
JDM headlights
Accord Rear lip
Tinted Windows(Recently done)
17 in. 5zigen 5ZR rims with 215/45/17 bridestone tires. About 7/32 left. GOOD
Interior:
Everything is STOCK! NO cracks or tears in the seats.
Currently thinking about replacing the seat belts with brand new OEM.
MOMO steering wheel, with quick release
Services performed recently:
Timing belts, brake fluid changed, power steering fluid changed, clutch fluid changed, oil changed every 3500 miles, EFI service(decarburization of chambers), Valve adjustment recently done. MTF recently changed. Clutch slave cylinder replaced with new OEM, Recently replaced waterpump, and basically all the gaskets and seals. Driveshaft’s recently replaced. Also did manual tensioner conversion. All the motor wok was done about 1 ½ years ago. I personally rebuilt the motor and had the machine work done at JMS motorsports in Duarte, Ca. The chassis itself has about 207,000 miles. MOTOR mileage to date after rebuild about 15-17k.
THE BAD: (not really that bad)
Needs Power steering rack(small leak at end seal)
Needs One wheel stud(stripped)
Antenna doesn’t work
ABS light on cuz I have wires disconnected
SRS light on due to steering wheel( I still have it)
VERY SMALL Coolant leak by thermostat.
Ok so…this is basically the car, if I think of anything else, ill be sure to update. If you have any questions, PM ME.
<center>
</center>
Motor:
JDM H22
Generic Header
A/c Removed
Drive train:
H23 transmission
OEM flywheel
HONDA NEW MTF ONLY!
Stance:
Spoon Upper Tie Bar
Exterior:
JDM headlights
Accord Rear lip
Interior:
<center>
</center>
west1502
Sep 19, 2011 12:38 PM
west1502
Jul 26, 2011 03:55 PM
bb4socal
Oct 13, 2008 07:27 AM
bb4socal
Mar 31, 2008 10:36 AM
bb4socal
Mar 26, 2008 08:04 AM
