Fan runs hours after being driven?
Old Mar 20, 2008 | 04:26 PM
CRIMEIII's Avatar
From: Manchester, New Jersey, United States Of America
Default Fan runs hours after being driven?
I've got a 1991 Honda Accord 4banger, standard.I've noticed recently that hours after it had been driven the fan is still going.I live in the North East and it's still pretty cold out so don't understand why it's still running?Just wanted to see if anyone has dealt with this problem before and what i can do to fix it before the battery takes a dump?
Old Mar 20, 2008 | 05:11 PM
billyrusa's Avatar
Default Re: Fan runs hours after being driven? (CRIMEIII)
Normally, the fan should run about 15 minutes after the engine stopped the temperature is above 223F. If it run much longer than 15 minutes, check:
1. #30 fuse in under-hood fuse/reply box.
2. #2 fuse in under-dash fuse/relay box.
3. #7 fuse in under-dash.
4. Engine Coolant temperature (ECT) swicth B that is located behind the water outlet housing. NOT the one in t-stat housing which is ECT A.
5. If all above are right, maybe a faulty Radiator Fan Control Module or a faulty diode. The Radiator Fan Control Module and the diode are located on the driver's side under the dash.
Old Mar 20, 2008 | 05:39 PM
hondadude's Avatar
Quick diagnose, when you shut off the engine [when it isn't really hot] and the fans are running, open the hood and follow the top radiator hose back to the head outlet. You'll see a sensor there [2 wire] unplug it; if the fan shuts off you've found the problem. Temp switch B
ricanxplaya
Jun 7, 2011 07:42 AM
harveyy
17
Mar 1, 2006 04:32 AM
b00sted4dr
Jul 25, 2005 05:28 AM
Answer
Aug 9, 2001 10:21 AM
