alternater belt is scraping against the bottom of thetiming belt cover
Old Mar 20, 2008 | 03:03 PM
otsegolectric's Avatar
Default alternater belt is scraping against the bottom of thetiming belt cover
And its making a whining noise. so i need to know how to tighten the belt because i'm assuming its a little loose. Or if you dont think thats the case let me know.
1994 honda prelude si.
Old Mar 20, 2008 | 05:43 PM
Speedra500's Avatar
Default Re: alternater belt is scraping against the bottom of thetiming belt cover (otsegolectric)
there is a bolt facing toward the front of the car just below the alternator, you need to loosen the bolt attached to the slotted bracket on the bottom, it is a larger bolt that has the swiveling piece attaches to. Once you loosen that bolt turn the tensioning bolt facing the front of the car until the belt is tight
Old Mar 21, 2008 | 12:52 AM
Default Re: alternater belt is scraping against the bottom of thetiming belt cover (Speedra500)
thanks.
Old Mar 21, 2008 | 01:53 PM
alright so i'm a little confused. i see two very similar bolts facing towards the front of the car. one of them is the tensioning bolt? also if i was looking towards the car from the front is the bolt i need to loosen on the bottom right of the alternator?
Old Mar 21, 2008 | 04:29 PM
SikB's Avatar
One of those two bolts, I think the left one, is very short and holds that bracket in place. If you were to unbolt it the alt would be able to swing forward and back freely given that you already loosened the big bolt. The other bolt on front is several inches long and you should be able to feel the exposed threads of that bold if you reach under the alt. If you turn that it will swing the alt in or out. If memory serves, those bolts are 12 mm each. The other bolt that you need to loosen to adjust is under the alt pointing toward the drivers side fender. It is much bigger like 15 or 17 mm I think. Remember to tighten it when you are done.
blackcomet94
Apr 20, 2013 03:04 PM
lude1888
Jun 6, 2007 09:26 PM
FBPPrelude
May 22, 2007 12:31 PM
djnikko
Oct 23, 2004 12:28 PM
satan_srv
Aug 27, 2002 01:21 PM
