Suspension & Brakes Theory, alignment, spring rates....
OEM Endlinks
Old Mar 20, 2008 | 02:33 PM
Spoon's Avatar
Default OEM Endlinks
Can someone post up a picture of the front and a picture of the rear endlinks?
Modified by Spoon at 12:38 AM 3/26/2008
Old Mar 20, 2008 | 03:59 PM
egsleepercivic's Avatar
I believe gsr and typer endlinks are the same
gl
Old Mar 20, 2008 | 09:56 PM
Targa250R's Avatar
be professional
Default Re: OEM Endlinks (Spoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">I believe gsr and typer endlinks are the same</TD></TR></TABLE>
I'm showing different part numbers for the rear links: 52303-SH3-020 (an '88-91 Civic part number, interestingly enough) for the GSR/LS vs. 52303-ST7-Z00 for the ITR.
The front links are also different because the ITR uses a vertical eye in the bar vs. the horizontal eye used in GSR/LS front bars.
Old Mar 21, 2008 | 12:11 AM
I have the gsr front bar and it has the same mounting points as the type r, which is different than the LS, ex/si(92-95) mounting points gsr is to the right, LS is in the main part of the page http://acuraautomotiveparts.or...ormal , I looking for the rears right now.
Old Mar 21, 2008 | 12:21 AM
I got the same part #'s for the rear I thought they were the same. They maybe the same just different part #'s, kinda like the crv ac braket and the del sol ac bracket. op if you want to be safe just get the ones for the type r 52303-ST7-Z00
Old Mar 21, 2008 | 06:44 AM
Targa250R's Avatar
be professional
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">I have the gsr front bar and it has the same mounting points as the type r, which is different than the LS, ex/si(92-95) mounting points gsr is to the right, LS is in the main part of the page http://acuraautomotiveparts.or...ormal , I looking for the rears right now.</TD></TR></TABLE>
Whoops, you are correct. GSR uses the same front bar and links as ITR (vertical bar eye), while the LS links are different (horizontal bar eye).
I screwed up looking at the numbers in the catalog because I chose an LS Special Edition (precursor to the GS), which shares its front bar with the GSR/ITR, not the regular LS.
Sorry for the confusion
Modified by Targa250R at 10:53 AM 3/21/2008
Old Mar 22, 2008 | 01:54 PM
Spoon's Avatar
Default Re: (Targa250R)
Hmm.. here i thought endlinks were universal...
Old Mar 23, 2008 | 07:23 AM
blaze the chemi's Avatar
Default Re: (Spoon)
http://www.jdmuniverse.com/for...ybars
A very useful webiste.
PreyStayShun
May 22, 2011 01:01 PM
HondaGSX
Jan 23, 2007 07:51 PM
AEMintegra22
Jun 24, 2006 09:42 PM
Nifty
Aug 5, 2004 03:41 PM
Johnny62
Oct 25, 2001 11:37 AM
