when driving i feel like my axles are making a clicking feeling??? not to sure
While driving my db around, The car has a some sort of clicking feeling throughout the car. I can really feel it through the gas petal and breaks. You can hear the "clicking noise" while decelerating. Im not to sure how to explain it much better, but I think it is my axles. Any help?
thanks, hoping to get it in this week to have someone take a look at it.
i just recently replaced both my driver and passenger side axels cuz the boots were cut it costed bout 35 a pop Did a DIY very simple job good luck
I agree. I had my teg just a week before this started. I bought from local acura dealership and they replaced the axel under limited warrenty. They said that the outer joint in it was worn. Not a bad job for DIY, just remember to get the ball joint seperator from Autozone, etc.
Check the condition of your CV boots. Are they leaking or torn? That is usually the cause and if they are then they must be replaced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbdEG6 »</TD></TR><TR><TD CLASS="quote">Check the condition of your CV boots. Are they leaking or torn? That is usually the cause and if they are then they must be replaced.</TD></TR></TABLE>
Exactly on the Dot.
if u take off the wheel and theres all this black greese everywhere behind the rotor then the cv boots torn exactly how i knew mine were messed up and its a mess under there if u change em but yea thats most likely ur problem
Exactly on the Dot.
Oreo-TeCk
Jul 1, 2007 10:33 PM
Shorty C
May 15, 2004 06:10 AM
