no fire h22
Old Mar 20, 2008 | 02:00 PM
spitfire600x's Avatar
Default no fire h22
hi guys, i have a honda accord 91 with h22 . i just change the tranny , distributor , coil , wires , spark plugs and put 2 new ground wires(one the the tranny and one the the engine)
i've chek my fuses and ground
what could be the problem?crank sensor , main relay , ground on thermostat or something like that?
i dont know what to do next
Old Mar 20, 2008 | 05:50 PM
hondadude's Avatar
Default Re: no fire h22 (spitfire600x)
The ECU uses the ground at the T-stat housing as it's reference.
But I'm trying to understand your post a little better;
So you changed trans then it wouldn't start, and you replaced the other parts?
Old Mar 21, 2008 | 02:41 PM
maybe i dont have the right conection at the thermostat..what color the wires should be?
Old Mar 23, 2008 | 07:52 AM
i found the problem. it was a ground neer the thermostat.
now the engine is running really bad i'm not getting gaz to the 3 and 4th cilinder.(i say this because the runners of the exaust wont go hot like the 2 others).
could it be not anough fuel pressure and the gaz wont go all the way trough the fuel rail for the 3,4 cilinder?i will do a fuel pressure test on monday.
or , its the injector that are broken? i disconect the injector and I plug it to a 12v batterie and made them click(all 4 have click and they are all clean).is it possible that the injector click without injecting fuel?
how you can chek if the injector have a pulse from the computer without the special test light tool?
i have compression to all 4 cilinders and spark to all cilinders...
if i reset my ecu will it resolve the problem?
or i'm in the wrong way???
sorry for the bad english, i'm trying my best to improve it.
dohcvtecforlife
Mar 4, 2009 05:16 PM
dsmcoco
10
Mar 24, 2008 03:31 AM
spettinger
May 31, 2004 05:44 PM
GSRACCORD
Aug 10, 2003 06:45 AM
