What got wet?
Old Mar 20, 2008 | 11:41 AM
NOFX's Avatar
H-T White Ops
Default What got wet?
This is just a question to satisfy my curiosity. The problem seems to have just been caused by something getting wet, but I'm not sure what exactly could have gotten wet to cause this symptom.
So I washed my engine bay the other day. I ran the car the entire time as I always do. I have never had a problem with any car I've done this to before.
I sprayed the Simple Green on. I let that sit and then sprayed the entire engine down with water. I never mask anything off (and have never needed to). I don't aim directly at the distributor, battery or alternator though.
Then I dressed the belts, lubed the latch and cleaned up the rest.
I walked inside for a second and when I came back out the car was off. I reached in and the keys were still in the ignition and there was still power in the car.
I started the car and it started right up but the idle seemed low and it fluttered. I revved the engine and it seemed to hesitate.
So I took it for a drive and first gear felt fine. I put it in second and it felt fine at first, but then bogged hard. All the other gears were fine.
After a few times of testing this, second went back to normal.
What could have gotten wet that caused just second to bog?
Old Mar 20, 2008 | 12:21 PM
BlueIntegraBoy's Avatar
Default Re: What got wet? (NOFX)
Whatever it was, it seemed to evaporate all the water after running.
Old Mar 20, 2008 | 12:32 PM
NOFX's Avatar
H-T White Ops
Well, the car was running the entire time I was washing. I'm thinking moving around might have caused the water to blow off of what it was in/on or shake off of what it was in/on.
I'm just not sure what could have gotten wet to cause this.
nub's Avatar
nub
Default Re: What got wet? (BlueIntegraBoy)
my guess would be tps, but who knows. like stated above the water must have evaporated eliminating the problem. i shut my engine off when cleaning and the only thing i try not to spray is the intake filter and havent ever had any problems afterwards
Old Mar 20, 2008 | 03:17 PM
fryguy190's Avatar
Default Re: What got wet? (nub)
yea all i could think of was that you might have gotten watter into the intake.
thats all i can think of.
after nine30
11
Apr 6, 2008 12:33 PM
dohc_profile
12
Apr 29, 2006 06:17 PM
bobby03civic
Honda Civic (2001 - 2005)
Mar 19, 2006 05:35 AM
Notahon DUH
Aug 12, 2004 09:48 AM
Sassafrass
10
Aug 28, 2003 12:13 PM
