vacuum lines?
Old Mar 20, 2008 | 07:30 AM
B16A CRX's Avatar
Default vacuum lines?
As of now i only have to vacuum lines connected. Brake bosster and the fuel pressure regulator line. I have a B16a in my crx. i have an obd1 manifold and the car has been converted to obd1. My rex has a map sensor on the firewall and one on my throttle body. but i have the one on my throttle body connected and not the one on my fire wall. On my throttle body there is a tube thing that can have a vacuum line connected. does this need a vacuum hose? How many vacuum lines need to be connected? In florida we do not need to pass inspection.
Old Mar 20, 2008 | 11:22 AM
dr_latino999's Avatar
Default Re: vacuum lines? (B16A CRX)
I have the bare minimum hooked up (local to you):
Firewall Map Sensor
Fuel Pressure Regulator
Brake Booster
PCV Valve
That's all you need.
Old Mar 20, 2008 | 04:53 PM
B16A CRX's Avatar
Default Re: vacuum lines? (dr_latino999)
do u have a picture of how u have ur firewall map sensor vacuum hose. where does ur pcv connect to. i have the pcv on my manifold but it can not see where it connects to
GameBoyeas
10
Jun 5, 2017 09:14 AM
roll8221
Engine Management and Tuning
Apr 1, 2015 11:29 AM
90R3x
Nov 29, 2014 03:27 PM
CRXREFIC
Dec 17, 2010 09:16 PM
juanchoenuncrx
Dec 26, 2007 05:03 PM
