94+ integra gauge cluster swap
Old Mar 19, 2008 | 10:23 PM
D16SiHatch's Avatar
Default 94+ integra gauge cluster swap
So i've spent a good bit of time lookin around and these are the two good links i have found to help with the cluster swap.
http://hondacrx881.tripod.com/gsrclusterswap.html
http://www.angelfire.com/dc/oregonimport/gsr.html
I kinda stumbled upon this swap and thought it came out looking really nice so i'm thinking i want to do it. that and because i still have my friends car that i pulled an engine from sittin in the garage and before it goes to the junkyard i figured i could just take the cluster and some wiring outa there too!
ok now to some questions lol
-This cluster is from a car that had an auto, will there be any issue using this cluster on my car which is a 5spd?
-Do the pinouts all look correct on that angelfire link i posted?
-what electronic vss should i use with my 93 ls transmission? will any electronic vss from later year b series engines work?
i think thats everything. if anyone else has anything useful to add pertaining to the cluster swap have at it.
-oh and since i have the donor car just sittin in the garage at the moment is there anything else i should get from it besides the cluster connections with plenty of wire, and the cluster itself?
Old Mar 20, 2008 | 11:38 AM
D16SiHatch's Avatar
Default Re: 94+ integra gauge cluster swap (D16SiHatch)
anyone?
Old Mar 25, 2008 | 07:38 PM
D16SiHatch's Avatar
ok well this will be my last bump
I just got the cluster out of the donor teg, and i have another question. In the writeup and in the info for the pinouts it only gives the pinouts for the b/16p connector, and the c/13p connector. Upon removing the cluster i found in addition to the previous 2, a 10wire blue connector, and also a 3 wire white connector. Are these going to be needed in anyway when i eventually swap this cluster into my ef?
sk8shorty012
21
Mar 11, 2011 05:03 PM
elbeanerhatch
Apr 25, 2009 08:59 AM
utn
Honda Civic (2001 - 2005)
Nov 12, 2007 01:48 PM
D-Money
Aug 7, 2006 01:21 PM
