code 17 and 43???
Old Mar 19, 2008 | 05:52 PM
dj-t's Avatar
Default code 17 and 43???
I have a 90 civic hatch with a bone stock b18a. Roughly about 5 months ago when I did my swap I replace my fuel pump also with a 190 walbro because I was planning on going turbo this summer. Worked some problems out and got the car started drove for a couple of days everything was fine until I went to pump some gas. Pumped a full tank got in the car drove away while at the light I was going to reset the trip meter to see how much mpg the new motor would consume I notice that it was on E (past the E mark). I hit a couple of bumps and the needle jump back to the full mark and then back down but every time it get to half tank the gauge reads just fine.
Also my speed gauge was bouncing for a while did a search on here and found that it was the speed cable but on my way to the junk yard the cable broke right in the sensor on the trans but I use a needle nose and pulled it out and replace it with the one I got at the junk yard. It works fine till this day.
Now that it is starting to get warmer when I drive on the freeway for about 15 to 20 minutes check light comes on and suddenly feels like it hauling a trailer but if I turn the car off and turn it back on it goes away and drives fine. I check it and the ecu was throwing a code 17 and 43 that is the speed sense and fuel system right.
I took the tank down and checked it, the connection at the pump was good soldered the connection and taped it good. Checked all the hose that goes to the tank all of them are on and tight. Fallowed the fuel lines along side the the car under the carpet looks fine. Replace fuel filter and check injector are snug and clips are on correctly. Checked speed cable on the trans and behind the cluster snaps in tight looks fine.
But I still get the same problem on warm days. I don't know what else to check for anyone ever had this problem before? What do you think that might be causing this? Can it be a bad injector? How can you test a injector to see if it is bad or not?
Any help would be appreciated.
Old Mar 20, 2008 | 02:09 PM
dj-t's Avatar
Default Re: code 17 and 43??? (dj-t)
Any assumptions??
Anyone??
Old Mar 23, 2008 | 11:13 AM
HOODLOVER's Avatar
WELL I GUESS NOT
Old Mar 23, 2008 | 04:59 PM
91ef'er's Avatar
i know 17 is the vehicle speed sensor but im not sure about the other one
thecorey
Oct 13, 2008 08:06 PM
dj-t
Apr 7, 2008 09:24 AM
EF9 JAMS!!!
Dec 10, 2006 10:26 AM
Steemo
May 14, 2005 12:01 PM
W0oT
12
Dec 10, 2003 10:47 PM
